Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 12:26 PM
capwater is starting off with a positive reputation.
oil pressure/knock 1997 V-6 4.2l
Greetings, new guy here, but I've been turning wrenches for 3 decades.
I have one of the dreaded V-6 motors, mileage 125k. Here are the symptoms:
1. knocks for a couple of minutes at startup, oil pressure reads fine
2. after a few minutes warmup, knock reduces to almost negligible, more of a slight tick, oil pressure still reads fine
3. after about 15 minutes at full operating temp idle will drop when stopped and oil pressure will drop quote a bit (no change in knock status), stepping on accelerator will increase rpm and bring oil pressure back
4. driving i do not notice any drop in power or oil pressure drop, runs fine even on highway at 75mph
5. no oil leak, recent change with filter and no coolant in oil.
Took it into the dealer who promptly said I need a new engine (over $4k), low compression in 2 cylinders was the diagnosis. Called around some other place for engines and talked extensively with a guy who was leaning towards oil pump replacement based on my description of the problem. Logic is I should have noticed a power loss if compression was bad. Surfing around I have seen a similar opinion relating to clogged pickup screen and bad pump. As this is an extra vehicle and just used to run to Lowe's/HomeDepot I can survive with a less than perfect situation and have the time to work on it. New oil pump quoted as $115 for the parts. A new engine really isn't in the budget, I would just sell it as is and get another used truck for a few grand.
Thoughts anyone? Much thanks.
  #2 (permalink)
Old 05-14-2008, 02:50 AM
streethealer's Avatar
streethealer is starting off with a positive reputation.
I'll reply just to give you a bump. My thoughts on your problem are worn main and rod bearings causing you to lose pressure at idle. Since you don't use the truck as a daily driver, I would venture to say that it has many more useable miles in it. If it were mine, I would use a little thicker oil in it at your next oil change and see if it makes a difference. If you use a 5w oil now, try a 10w or 15w oil. I have read that some people use 15w oil and have zero problems with it. I'm not big on oil additives or so called snake oil treatments but if you are maybe they will work for you. I don't think that the oil pump would cause the symptoms that you described. Good luck and let us know how you make out.
__________________
Kevin
1999 F-150 4x4 4.6L 3.55 F/R
In other words.....Bone Stock
I work on people for a living
  #3 (permalink)
Old 05-14-2008, 06:48 AM
Thanks for the reply. An update; as a result of my recent oil and filter change I don't have the bad knock on startup anymore, just a slight ticking which doesn't go away regardless of engine temp. I'll give the 10W oil a shot since it is the cheapest solution out there.
  #4 (permalink)
Old 05-15-2008, 02:31 AM
bokker is starting off with a positive reputation.
hi, it is good advise using thicker oil so long as it is for a short term solution. my 97 v6 had the same problems and i also had no way out as the truck was needed to run. i took it a stage further and put STP oil addative to really thicken things up. it lasted 2 months but payed the price of a new crankshaft and a full rebuild. good luck bokker.
  #5 (permalink)
Old 05-15-2008, 07:54 PM
monckywrench is gaining momentum as a positive member of FTE.
Start looking for a good salvage yard engine you can hear run.
$4K is too high to invest in most trucks that old. Many complete trucks go for that much!
My friend just scored an excellent used 2000 4.2 for $300, which beat the one I found for $500.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
