05-13-2008, 12:26 PM
oil pressure/knock 1997 V-6 4.2l
Greetings, new guy here, but I've been turning wrenches for 3 decades.
I have one of the dreaded V-6 motors, mileage 125k. Here are the symptoms:
1. knocks for a couple of minutes at startup, oil pressure reads fine
2. after a few minutes warmup, knock reduces to almost negligible, more of a slight tick, oil pressure still reads fine
3. after about 15 minutes at full operating temp idle will drop when stopped and oil pressure will drop quote a bit (no change in knock status), stepping on accelerator will increase rpm and bring oil pressure back
4. driving i do not notice any drop in power or oil pressure drop, runs fine even on highway at 75mph
5. no oil leak, recent change with filter and no coolant in oil.
Took it into the dealer who promptly said I need a new engine (over $4k), low compression in 2 cylinders was the diagnosis. Called around some other place for engines and talked extensively with a guy who was leaning towards oil pump replacement based on my description of the problem. Logic is I should have noticed a power loss if compression was bad. Surfing around I have seen a similar opinion relating to clogged pickup screen and bad pump. As this is an extra vehicle and just used to run to Lowe's/HomeDepot I can survive with a less than perfect situation and have the time to work on it. New oil pump quoted as $115 for the parts. A new engine really isn't in the budget, I would just sell it as is and get another used truck for a few grand.
Thoughts anyone? Much thanks.
