Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 12:03 PM
reifwj's Avatar
reifwj is starting off with a positive reputation.
Dual Vaccum Dizzy
I'm cleaning out the garage, ridding my self of the old engine, and found what looks like a dual vaccum dizzy. I believe this is what the 390 had on it before. are there any advantages to the dual vaccum dizzy? Would it be work rebuilding, or should i just junk it?
__________________
Bill,
1968 F250 (soon to be brown and orange)
Camper Special, 390 4 Barrel, C6, 4.10 rearend
MY TRUCK
2001 Dodge 2500
Quad Cab 5.9
FAMILY TRUCK
my wife drives a Honda, but she bought me the Ford.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-13-2008, 12:15 PM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
No advantages at all. It was an emissions thing. You can just use the front port or replace the advance unit with a single unit.
__________________
Bear 45/70
Gimp Racing
Don't pick a fight with an old man. If he is too old to fight he will just kill you.
  #3 (permalink)
Old 05-13-2008, 01:19 PM
Redmanbob's Avatar
Humble servant of my Peni
Redmanbob is gaining momentum as a positive member of FTE.
This whole dual vac dizzy thing has been on the plate somewhat often right here lately. From reading the posts, is it my imagination or ? Is the main purpose for this style dizzy to coverup the fact that the ported setup was causing overheating issues ? And as a resolution to a simple problem they created a band aid part with extra gizmos to go wrong and require yet more$ to replace/fix. ???????????? Inquiring minds want to know.
__________________
66 F100 352 V8
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/619321-russ-east-vs-west-3.html
  #4 (permalink)
Old 05-13-2008, 01:25 PM
Bear 45/70's Avatar
Quote:
Nope, it retarded the timing on decel. to improve emission numbers, NOX if IIRC. Had nothing to do with any heating issues. I have never heard of ported vacuum causing overheat problems if the system was working properly.
__________________
Bear 45/70
Gimp Racing
  #5 (permalink)
Old 05-13-2008, 01:28 PM
Redmanbob's Avatar
? Guess I read those posts wrong ?? could of sworn there was mention of a thermally activated vac unit for the temp issue in traffic.. but then I have read a lot of crap wrong before..
__________________
66 F100 352 V8
  #6 (permalink)
Old 05-13-2008, 01:58 PM
Bear 45/70's Avatar
Different deal all together. My 1984 F250 with a 460 has what you are talking about. Single advance unit with ported vacuum and manifold vacuum to the thermo switch. Normally the ported vacuum runs the advance, but if the engine temp gets above a certain temp, IIRC 210° or 220°, the switch changes the input to manifold vacuum, there by advancing the timing and increasing idle speed to cool the motor down. Only works when you are stuck in traffic or idling a lot in hot weather. No dual diaphragm involved.
__________________
Bear 45/70
Gimp Racing
  #7 (permalink)
Old 05-13-2008, 02:52 PM
Redmanbob's Avatar
ahh!! hmm gets me to thinking as mine heats up while idling. Either a similar part adapted or a manual means of the same thing "That would require me paying attention though" LMAO!
__________________
66 F100 352 V8
  #8 (permalink)
Old 05-13-2008, 04:58 PM
Bear 45/70's Avatar
Either put a "T" where the temp sensor is or find one of the thermostst housings that has the threaded hole for the sensor.
__________________
Bear 45/70
Gimp Racing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
