Im running 325-60-20 tires on the stock rims (f350 srw CCLB 6.4 auto 2.5 level kit )there about 35.5 tall....i changed out to 4.10 gears....raised my rpm 200 at 75 mph.....gps verified it corrected my speedo to read 2mph fast at 80mph (speedo reads 80 im really going 82)....if your gonna run 37" tires i believe 4.30 gears would put you back to stock..the diff between 4.10 amd 4.30's was another 100 rpm at speed....also measure your tires mounted to get a (real) height as some 37" tires are 36 or 36.5"
4.56 would put you even higher rpm wise if you drive alot of highway...if your towing heavy i prob would stay away from 4.56 cause the deeper you the gears the smaller the pinon.
also i used prescion gears and the new 08 trucks are so quiet inside i could hear a little whine. most after market gears all make gears for the rear 10.25 but not the 10.5 rear end.. the use a thicker pinon spacer to make up the diff....I changed the rear back out after 3k miles and went with ford factory for the rear which cost an extra 200.00 but there worth it. plus changed out and put factory bearings back in the rear as the koyo ones that came with the kit i had 1 go bad. the bearing kit had 1 timkin oinon bearing but the carriers were koyos?
hope this helps.
