Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 11:04 AM
bozzzz94 is starting off with a positive reputation.
1994 4.0 A/C Question
I haven't been on here for awhile. I've been deployed-just got back. Okay-a couple of questions. My compressor is screaming to the point in threw the belt. I'm sure the bearing/clutch is bad. For right now-I disconnected the electric lead-and threw on another belt to help make it through the week. I just bought a new compressor, dryer bottle, and an orifice filter, but haven't done anything yet.
Here is the question. I'm worried about contaminating the evaporator box or the condenser. I know that moister can ruin them. That is why I'm thinking I should have the system vacuumed out first. What do you think?
Should I have the system vacuumed out-then change out my orifice tube and compressor?
or
and here is where the confusion sets in. If I do this won't I have moisture in my system again after I break open the system and replace the components after I have it vacuumed?
I'm confused here. Could I get a pointer from someone that had crossed paths with this situation respond.--Respectfully Boz
__________________
1994 Extended Black Sport 4.0 2 wheel drive
1994 Extended Blue/gold 4.0 Eddie Bauer 4 whl-drive
1993 Extended Blue/gold 4.0 Eddie Bauer 4 whl-drive
1992 Shorty Blue 3.0 2 wheel drive
+1989 Extended Red 3.0 2 wheel drive
="5ive" Aerostar's P-R-I-C-E-L-E-S-S signed B O Z
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-13-2008, 12:03 PM
copper_90680's Avatar
copper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to behold
I would just ask an A/C shop to discharge the system first. They get your refrigerant for free, so they will be more than happy to do that at no charge.
Then you can open up everything and flush all the lines, the condenser and evaporator. You will be surprised how dirty they can be, at least mine was.
Then just put everything back together with new O-ring, evacuate and charge it up.
If your system is on R-12, now is the time to convert it to R-134a.
It's not really that difficult. I bought an A/C vacuum pump on Ebay for about $100 and it really saved me a lot of money in the long run.
Also, welcome back from your deployment
__________________
Tung
'93 3.0L Aerostar 2WD
'95 4.0L Aerostar AWD
'93 3.8L Taurus
Please check out our guideline
http://www.ford-trucks.com/guidelines.html
Wife? What wife? Oh, The Supreme Commander!
  #3 (permalink)
Old 05-13-2008, 02:39 PM
Thanks for the advice Copper. Well, I kind of did the backwards thing. My system must have stuck and I was worried about an over-charge. I bleed it off at the low pressure side already. When my AC wasn't cold I was going to throw a bottle of R-132A in. Well, it was over-charged by the gauge. I thought there must be a blockage somewhere and since these compressor's have soft metal-meaning that the office tubes usually have shards of metal plugging them up I thought that my system had in other words "a blocked artery".
How can I flush the lines you spoke of? Push compressed air with a nozzle threw the lines like when we hook a garden hose to the inlet outlet of a stuck heater core?
A little confused you can tell. I has another van one time (GMC Safari). They vacuumed it out and then I broke the system open when I got back and installed a new orifice tube. Well, that was before I knew about systems getting moisture in them or the desicant in the dryer bottle getting messed up. They damn thing even works till this day with doing everything wrong. I converted it over to the new from the old R-12 and not even a problem. -Thanks Boz
__________________
  #4 (permalink)
Old 05-13-2008, 02:56 PM
I used something similar to this
eBay Motors: Robinair 17595 Automotive Flush Gun Kit R12 & R134A (item 120260900383 end time Jun-10-08 08:51:19 PDT)
Also, they have flush solvent there or you can buy them at any autopart store. It's worth every penny, ortherwise the debris you have in there now will really destroy your new compressor.
I usually remove the evaporator and the condenser from the van and flush them outside. It's a lot easier that way. They are pretty easy to remove.
As for the lines, since you are redoing them, might as well take all the lines off and flush them through.
There are two things you don't want to flush, they are the compressor and the dryer. If the compressor goes bad, replace it. If the system is opened up, replace the dryer. You will be glad you did.
Good luck and holler if you need help.
__________________
Tung
'93 3.8L Taurus
  #5 (permalink)
Old 05-13-2008, 05:28 PM
cookkd is starting off with a positive reputation.
I went through this exercise about a year ago. I used some a/c flush I bought at AutoZone, and blew it out with my air hose. One of the biggest performance improvements was removing the evaporator and cleaning it, inside and out. The evap is about a foot square (roughly), and mine had a round open area for air to flow through that was about the size of a tennis ball. The rest was clogged up with debris, mostly leaves. Really improved air flow after it was cleaned.
Klaus Dieter Cook
Houston, Texas
__________________
'90 Eddie Bauer Ext, 3.0 - 254K (Parts Car)
'91 XLT Ext, 3.0 - 124,000 (slowly becoming an EB)
'86 Caddy Fleetwood FWD - 115K
'00 Merc Grand Marquis LS - 21K
'99 Merc Mountaineer - 112K
'92 Merc Cougar LS, 25th Anniv Edition - 98K
  #6 (permalink)
Old 05-13-2008, 10:27 PM
99f350sd is starting off with a positive reputation.
I have a small vacuum thingy you run with a compressor they are cheap and they work...I have never had an ac problem I just charge em up and never clean or flush and always had good luck go figure. I use the vacuum thing now though. Never touched and orifice tube...
Dick
__________________
99 F350 5.4 Lockers,Warn winch,Hubs..Diablo Predator
MDII Plow, 200 amp alt timbrens,Revo's
85f150, Two 96 aero*awd 4.0 ext. 05 mountaineer V8 Awd
Lever's are cool enough for me too...LOL
  #7 (permalink)
Old 05-14-2008, 01:18 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
However, to use the air powered one, you need a large air compressor with a high CFM rating. If you do not have a large air compressor, get an electric pump, which does pull a deeper vacuum anyway.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #8 (permalink)
Old 05-14-2008, 08:27 AM
Quote:
What he said!
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
