EGR valve - Ford Truck Enthusiasts Forums
EGR valve
Old 05-13-2008, 09:19 AM
jwillyf150's Avatar
jwillyf150 jwillyf150 is offline
jwillyf150 is starting off with a positive reputation.
EGR valve
Where is the egr valve located on 5.4? And could that be the reason for an P0442 code ?
Old 05-13-2008, 10:13 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
It is not the reason. A P0442 code is due to a detected leak in the evaporative emissions system. Has nothing to do with the EGR system.
Click on the word SEARCH and enter your fault code to find previous discussion. You should find the answers to your questions fairly readily.
Steve
Old 05-13-2008, 10:58 AM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
Did you buy this from a dealer? If you just recently purchased it, I would consider taking it back to the dealer and have them fix it.
Old 05-13-2008, 01:24 PM
FatalErrorz FatalErrorz is offline
FatalErrorz is starting off with a positive reputation.
I copied and pasted instead of typing it myself...
Symptoms: You likely won't notice any drivability problems.
Causes: A code P0442 most likely means one or more of the following has happened:
A loose or improperly affixed gas cap
A non-conforming gas cap (i.e. not factory/original brand)
A small leak/hole in a fuel vapor hose/tube
Other small leak in EVAP system
Faulty vent o-ring seal
Possible SolutionsWith a P0442, the most common repair is to:
Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
Otherwise, replace the gas cap, or
Inspect the EVAP system for cuts/holes in tubes/hoses
unplugging egr valve patrickke 6.0L Power Stroke Diesel 12 02-25-2010 01:47 PM
egr valve for 2006 ford diesel fix charschutt New Member Introductions 2 08-07-2009 09:53 AM
EGR Valve dantsg 1997 - 2003 F150 12 04-26-2009 04:59 PM
egr valve mrmcdb2005 Ranger & B-Series 13 09-15-2004 09:04 PM
egr valve mathelm Ranger & B-Series 1 01-14-2003 04:07 PM
Tags
2000, 2004, 2005, 2006, 54, egr, f150, fix, ford, lightning, located, location, p0442, v8, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
