Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #16 (permalink)
Old 05-15-2008, 08:17 AM
Aggie05 is starting off with a positive reputation.
IS the cycling switch the on located on the dryer? Do i have to take out the evaporator to flush it? I was just going to try to flush it as it sits in the truck.
Thanks for all the great info.
__________________
92 Ranger 2.3 ltr stick shift.
03 Nissan 350z
  #17 (permalink)
Old 05-15-2008, 09:18 AM
lsrx101 is gaining momentum as a positive member of FTE.
Yep, the cycling switch is on the dryer.
No, you don't have to remove the evaporator. That's why I said you may have to get creative. Heater hose and clamps work good, you just have to assure ALL of the solvent is out.
Just a note about flush solvent;
I've seen some that is almost like a soap solution. Stay away from this stuff unless you have access to an actual flushing machine. If you bought your solvent at one of the chain parts stores, I think that's what you may have.
Any solvent that you use needs to have a low evaporation point and not leave a residue. Think solvents like toluene, lacquer thinner, alcohol, etc. that evaporate quickly. Lacquer thinner works very well for flushing and is fairly cheap.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #18 (permalink)
Old 05-15-2008, 09:29 AM
Thanks for the help, ill check whats in the can tonight when i get home. Im guessing its some sort of alcohol/solvent or similar b/c its pressurized and said on can wont leave any residue behind.
WOuld it be logical to flush evaporator from top to bottom?
THX again!
__________________
03 Nissan 350z
  #19 (permalink)
Old 05-15-2008, 06:38 PM
THX again!
The solvent that you have should be fine. The solvent that I'm thinking of comes in a plastic bottle, IIRC the brand is FJC.
I usually go both ways with the solvent and the drying air on evaporators. That pressurized can should be just the trick for the evaporator if it has a rubber tipped nozzle. There might not be enough for the remaining parts that you are going to reuse so have a quart of thinner on hand for flushing and cleaning the rest of the parts.
As far as dye, when you buy your R134a get 1 can with UV dye and charge it as a liquid (upside down) first. That will make leaks easier to find down the road. Remember, no other additives, boosters or sealers. Just virgin refrigerant or refrigerant with UV dye.
__________________
  #20 (permalink)
Old 05-15-2008, 10:53 PM
PUlled orfice tube today covered in black goop, im guesssing black death. As i spin compressor i hardly feel a push or a pull so im guessing its shot. IVe replaced all hoses, dryer and condenser. Will buy a new ac compressor but wondering if i can keep evaporator?
__________________
03 Nissan 350z
  #21 (permalink)
Old 05-16-2008, 01:06 AM
Ooohh. That's not real "Black Death", but darn sure close enough. All hoses, dryer, condenser, accumulator and compressor. The evaporator, luckily, can be flushed. The orifice tube usually holds back the goop.
Really sorry about your luck Aggie05.
The good news is that you will have a "new" system when you are done.
__________________
  #22 (permalink)
Old 05-16-2008, 08:13 AM
photos of orfice tube
[IMG][/IMG][IMG][img=http://img369.imageshack.us/img369/4530/dsc00045ko9.th.jpg][/IMG]
[IMG][/IMG]
__________________
03 Nissan 350z
  #23 (permalink)
Old 05-16-2008, 08:49 AM
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
Quote:
Originally Posted by lsrx101 View Post
the original type will be ok, but if you still have a choice get a blue one.
I had been using the blue orifice on conversions, and was talking with my local a/c tech one day, and he advised that on Fords it was best to use the red orifice. I changed my 86 to the red, and sure enough, it worked much better. The truck will cool in hot Texas weather in bumper to bumper traffic. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
  #24 (permalink)
Old 05-16-2008, 08:51 AM
Odd, i bought a red one but then somebody else told me use the blue for 134 conversions. *shrug*
__________________
03 Nissan 350z
  #25 (permalink)
Old 05-16-2008, 12:06 PM
Quote:
You are correct, I was thinking a bit sideways. The blue o-tube works best in many GM systems and the red one is preferred for most Fords.
__________________
  #26 (permalink)
Old 05-16-2008, 06:03 PM
The differences I noted were quicker cool down, and better cooling at low speeds. My 86 sometimes got too damned cold. The system also seems to be just a bit touchy on the amount of charge. jd
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
