If your tires are taller than the original tires your odometer will understate the miles traveled (therefore your cakculated MPG will be understated) and you will be traveling faster that the speedometer indicates.
Also, taller tires will act like you have taller gears (lower numerically) in the diffs. The taller tires will reduce the mechanical braking effect because of the leverage of the greater radius. The taller tires may have a slightly reduced rolling resistance.
The larger wheels will allow more air circulation around your brake rotors keeping your brakes cooler.
All that said, a difference in overall height of an inch or so may just barely be noticeable - depends on how sensitive you are to your vehicles performance.
__________________
Jim in Central NY
'79 2WD F-150 Lariet w/302,4spd OD, 228,965 mi. (Original Owner!)
'02 4X4 Navigator (Newbie)
