Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 08:37 AM
2000Expy's Avatar
2000Expy is gaining momentum as a positive member of FTE.
Question Expy 4x4 16" or 17" wheels - pros/cons?
I'm wondering whether I should continue to use the 17" wheels on my truck. It originally came with 16" wheels, but I bought the 17's from a brother-in-law and they had tires on them. Anyway, I've had these through the original and one set of Revo tires.
Question is, what's the advantages and disadvantages of the two wheel sizes? The larger wheel reduces the towing load, but I don't really tow much. I'm not sure about gas mileage or drivetrain wear, but wonder.
__________________
2000 Expedition XLT 4x4
4.6L Triton engine
Bilstein shocks
16" Michelin X® Radial LT
Kenwood 10 CD-changer
Virginia Chapter
I'm never serious unless I should be.
  #2 (permalink)
Old 05-13-2008, 10:21 AM
pdqford is starting off with a positive reputation.
If your tires are taller than the original tires your odometer will understate the miles traveled (therefore your cakculated MPG will be understated) and you will be traveling faster that the speedometer indicates.
Also, taller tires will act like you have taller gears (lower numerically) in the diffs. The taller tires will reduce the mechanical braking effect because of the leverage of the greater radius. The taller tires may have a slightly reduced rolling resistance.
The larger wheels will allow more air circulation around your brake rotors keeping your brakes cooler.
All that said, a difference in overall height of an inch or so may just barely be noticeable - depends on how sensitive you are to your vehicles performance.
__________________
Jim in Central NY
'79 2WD F-150 Lariet w/302,4spd OD, 228,965 mi. (Original Owner!)
'02 4X4 Navigator (Newbie)
  #3 (permalink)
Old 05-14-2008, 02:08 PM
Darth Baiter is new and has a neutral reputation at this point.
Mine's on the beach a lot. I'll take every inch of clearance I can get. Besides the 17" wheels make the truck look better than 16's.
__________________
99 Expy XLT
4.6L 4x4
Sand Sled
K&N Air Filter
Flowmaster Force II Exhaust
Bilsteins
Energy Suspension Bushings & Links
Hellwig Rear Sway Bar
Bridgestone Dueler Revos
  #4 (permalink)
Old 05-16-2008, 01:12 PM
2000Expy's Avatar
Thanks guys. As an engineer, looks are not usually my prime concern; I guess it's a fault. I believe the height difference is neglegible because the tire profile is lower for the 17" than the 16" wheels. My guess is that Ford did it more for styling than function.
__________________
4.6L Triton engine
Bilstein shocks
Virginia Chapter
  #5 (permalink)
Old 05-16-2008, 01:35 PM
alloro is starting off with a positive reputation.
Quote:
Originally Posted by pdqford View Post
If your tires are taller than the original tires your odometer will understate the miles traveled (therefore your calculated MPG will be understated) and you will be traveling faster that the speedometer indicates.
Here's a webpage that calculates what happens with a change in tire size.
Tire Dimensions Made Simple - Discount Tire Co.
  #6 (permalink)
Old 05-19-2008, 06:17 PM
2000Expy's Avatar
1.5" difference in overall height, -33 rpm diff in spin and 3 mph faster than reading
__________________
4.6L Triton engine
Bilstein shocks
Virginia Chapter
  #7 (permalink)
Old 05-19-2008, 06:18 PM
2000Expy's Avatar
You know I don't think I've gotten any rep points since I've been here.
__________________
4.6L Triton engine
Bilstein shocks
Virginia Chapter
  #8 (permalink)
Old 05-19-2008, 10:20 PM
sbclemens is starting off with a positive reputation.
Didn't the stock 17's come with larger rotors/calipers?
__________________
98 Expy XLT 4x4 5.4L
  #9 (permalink)
Old 05-21-2008, 03:12 PM
cbradford is starting off with a positive reputation.
The 17" will handle better
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
