serp. belt - Ford Truck Enthusiasts Forums
serp. belt
Old 05-13-2008, 08:09 AM
Todd K Todd K is offline
Todd K is starting off with a positive reputation.
serp. belt
my serp. belt has been squeeking for a while now. any one else have this problem and what can i do to fix it? thanks
Old 05-13-2008, 09:36 AM
mattd17's Avatar
mattd17 mattd17 is offline
mattd17 is starting off with a positive reputation.
you could try a belt dressing, which would only be temporary...... best option would be to replace it.... what year is your ride? how much mileage? are you sure its the belt itself, and not a pulley on the idler, or alternator?
Old 05-13-2008, 11:27 AM
FatalErrorz FatalErrorz is offline
FatalErrorz is starting off with a positive reputation.
I read on here about some guy who cleaned his splines with a wet paintbrush while the engine was running and that took care of the noise. He'd changed belts, pulleys, tensioners, alternator,etc. It turned out to be the auto car wash blowing crap onto his belt which made it squeak. But if you have 5 trillion miles on it, then you should probably change your belt.
Old 05-13-2008, 11:53 AM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
I agree with Matt- it could be lots of things, but without knowing mileage etc.. Ford has had issues with tensioners in the past, but as Fatal says, the belt could be dirty as well. If you have 90K on it, I'd probably change the belt. Goodyear Gatorback is a great belt.
Old 05-13-2008, 03:14 PM
NASSTY's Avatar
NASSTY NASSTY is offline
NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.
+1
Get a Goodyear Gatorback belt.
Tags
2005, belt, f150, ford, gatorback, goodyear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
