Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 06:32 AM
lugnut05's Avatar
lugnut05 is starting off with a positive reputation.
rear brake lines
My 1987 Bronco II is equipped with rear anti-lock brakes.
Recently the line ruptured from the pumpkin to the driver's side wheel cylinder. Foolishly I bent up a new line and figured I was good to go.
Apon bleeding I found the next weakest link, the line from the front that runs along the frame to the anti-lock control valve.
I know it will not stop there and will go for replacing all the rear lines.
Question is about bleeding them. I notice the Anti-lock control valve has a bleeder.
What is the proceedure for getting them bled properly ?
-Joe W
__________________
Toy List:
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4 Manual Hubs
1977 Harley Davidson FLHS
1977 Harley Davidson XLH (would like to sell)
1969 Mercury Cougar Eliminator
(currently under construction )
1934 Harley VLD project
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-14-2008, 06:22 PM
rebocardo is a name known to allrebocardo is a name known to allrebocardo is a name known to allrebocardo is a name known to allrebocardo is a name known to allrebocardo is a name known to all
right rear, left rear, abs, right front, left front.
remove the abs and clean the screen.
__________________
The Year 2008 Anno Domini -
May it bring a great year of Revelations to you.
  #3 (permalink)
Old 05-22-2008, 01:57 AM
madclone is starting off with a positive reputation.
all hydraulic lines hate air bubbles some of the bubbles go up (to the master and it's fluid tank), some of them can't go up because they are trapped in different line bendings etc. So your main objective is to get rid of the air that can't go up. To do so, put one end of a rubber hose on the bleed screw, submerge another end in breack fluid. This will prevent air from "outside" getting back into the line. Then unsrew the bleeder, and start working on the brake pedal checking fluid level in master's container constantly untill the air stops coming from the submerged hose. Then tighten the bleeder. Do same for another wheel. After that check your brakes. Be carefull. I know this is not how things are described in books, but when there's noone to help and you need the car fast - this trick works fine. Did it three times on two different cars. But if you are not well experienced to determine whether the brakes are working OK or not, don't do it )
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
