Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 01:48 AM
Fluid Power is starting off with a positive reputation.
Noob question about head unit removal
I'm not really a noob to Audio or Fords, just in this situation.
I have an '04 F350 with an in-dash 6 disc changer. I want to hard wire my Sirius Radio audio out into the stereo. I can either use the Fm Direct cable or the "Audio out". I don't know what the Stock Head Unit has for inputs ??? I could figure it out if I could figure out how to pull the unit out.
Any hints would be helpful.
Thanks.
__________________
Black 2004 F-350 4x4 SuperCrew 6.0L Lariat
4" Turbo back stainless exhuast, SuperChips 1704 Tuner, 4" Rear Lift levelled to 7" in Front, Clearance Lights w/visor, Hood Deflector, Pillar Mount EGR and Boost gauges, 35" Kumho M/T's on 17" chrome wheels, chrome fuel door.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-13-2008, 03:37 PM
Beerstalker's Avatar
Beerstalker has a good reputation on FTE.Beerstalker has a good reputation on FTE.Beerstalker has a good reputation on FTE.
There is a tool you can buy at Walmart, Autozone, or pretty much any store that sells stereo stuff. The 04 radio will have 2 holes on each side of the radio, the tool goes into these holes, then you press the loops slightly outward and pull the radio toward you. Some people have made their own tools using wire hangers, or just pushed nails into the holes. The tool is less than $5 so I just bought one.
If you have a Circuit City or Best Buy near you, them might even let you borrow the tool for a couple minutes or do it for you if you ask nicely.
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
  #3 (permalink)
Old 05-13-2008, 10:37 PM
Thanks for the reply. I guess I'll have to go find the tool. I tried the bent coat hanger and couldn't get it to work.
Does anybody know what the stock deck comes with for Inputs and Outputs?
__________________
  #4 (permalink)
Old 05-13-2008, 10:53 PM
bgalaxy67's Avatar
bgalaxy67 is starting off with a positive reputation.
When using the coat hanger. run them into the holes till they stop, then back them up about 1/4" then take and push outwards from eachother. While doing that, pull on the deck to get it to slide out.
The stock deck won't have any inputs/outputs on the rear of the deck
__________________
If the listening level is too loud, promptly inform the driver, so he may pull over, and let you out
My Excursion
Wife's 250
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
