Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 01:07 AM
AC94EXPLORER is starting off with a positive reputation.
spark plugs are fauling
i have a 94 ford explorer i ran autolites in them the first time i did a tune up and the plugs were fauled out 2500 miles. so i ran the bosch ones and now they are fauling out again i dont know whats the spark plug one the back passenger side had hard bubbles on it and it was black. drivers side back i was black. the drivers side plugs as you face them the first (left side) and second had gas on them. i was told by my mechanic that these 4.0's are picky on spaerk plugs and told me to run the motorcrafts. anyone have any sudjestions? i dont wanna keep changing out these plugs. tomorrow im buying the motorcrafts and we will see how long they last. could it be my coil pack?
  #2 (permalink)
Old 05-14-2008, 08:52 AM
CMOS is starting off with a positive reputation.
While most Fords like MC plugs, the Autolites should have been fine. It sounds like you have other issues.
When was the last time the plug wires were changed?
How many miles on the truck?
Have you done a compression test on each cylinder?
Yes, it could be the coil pack, or a combination of things. Start investigating them one at a time.
CMOS
__________________
2001 Sport-Trac, 2WD, 4.0, 5R55E Auto, 4.10 gearing
"Faith in Government defies both history and reason."
  #3 (permalink)
Old 05-14-2008, 09:30 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
The spark plug wires are only good for 60,000- 100,000 miles, about the life of the plugs. The wires should be replaced. You can test the coil packs to see if the primary and secondary resistance is to spec.
Autolite makes the motorcraft plugs, so the Autolites should have been fine, assuming they were the correct double platinum plug. I have tried Bosch before, and never got more than a couple thousand miles out of them.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #4 (permalink)
Old 05-14-2008, 11:22 PM
the wires has 3k on them. it's goin to the shop on monday. im gonna see if i can take my coil ouit and have it tested at autozone.
  #5 (permalink)
Old 05-15-2008, 08:57 AM
YOU can take the coil out and have it tested.
CMOS
__________________
  #6 (permalink)
Old 05-15-2008, 09:00 PM
Quote:
CMOS
thats what im gonna do
  #7 (permalink)
Old 05-17-2008, 06:50 PM
you have to use a voltage tester how do i find out the specs?
  #8 (permalink)
Old 05-19-2008, 07:15 PM
i found out i have a cracked head my spark plug on the passenger side back has bubbles and thats a sign of cracked head.
  #9 (permalink)
Old 05-19-2008, 07:32 PM
"Has bubbles"? What does that mean? Please explain further.
CMOS
__________________
  #11 (permalink)
Old 05-19-2008, 09:35 PM
If that is the case then you should be able to confirm it with compression testing and a coolant system pressure test.
Keep us posted as to what happens...
CMOS
__________________
  #12 (permalink)
Old 05-19-2008, 09:40 PM
we did a pressure check and it holds pressure. the water is going through the exhaust. im gonna get both heads replaced for 1500. hopefully it will last me a few months.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
