i have a 94 ford explorer i ran autolites in them the first time i did a tune up and the plugs were fauled out 2500 miles. so i ran the bosch ones and now they are fauling out again i dont know whats the spark plug one the back passenger side had hard bubbles on it and it was black. drivers side back i was black. the drivers side plugs as you face them the first (left side) and second had gas on them. i was told by my mechanic that these 4.0's are picky on spaerk plugs and told me to run the motorcrafts. anyone have any sudjestions? i dont wanna keep changing out these plugs. tomorrow im buying the motorcrafts and we will see how long they last. could it be my coil pack?
The spark plug wires are only good for 60,000- 100,000 miles, about the life of the plugs. The wires should be replaced. You can test the coil packs to see if the primary and secondary resistance is to spec.
Autolite makes the motorcraft plugs, so the Autolites should have been fine, assuming they were the correct double platinum plug. I have tried Bosch before, and never got more than a couple thousand miles out of them.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDry filter
we did a pressure check and it holds pressure. the water is going through the exhaust. im gonna get both heads replaced for 1500. hopefully it will last me a few months.
