Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 12:07 AM
jwford's Avatar
jwford is starting off with a positive reputation.
does the compressor run on my 98 explorer xlt?
hey guys, i've always had an ongoing blendor problem that i fixed from hanging around the forum. also i've had an ongoing (another thread from long ago) issue with my air blowing out of my defroster only. i gave up on that after not finding it. it's ok for now...
now, i want to know how to tell if my compressor is running. the air does not blow cold so it's either the compressor or it needs freon in my 98 explorer xlt.
i've never put any in the 6 years i've had it.
with my explorer idleing a little rough, it's hard to tell if it kicks in, or not.
anybody know a sure fire way of finding out before i take it to the mechanic and he laughs as i'm emptying my wallet in front of him?
__________________
2008 Ford F150 Quad cab RED
1998 Ford Explorer XLT,Black
  #2 (permalink)
Old 05-13-2008, 01:11 AM
eallanboggs is starting off with a positive reputation.
Look at the clutch face. Does it spin at the same speed as the serpentine belt or freewheel all the time. Can you hear and see the clutch energizing? This ain't rocket science.
  #3 (permalink)
Old 05-13-2008, 09:56 AM
jwford's Avatar
Quote:
thanks Professor Einstein---to me it is!
sooo, if it freewheels it don't work? also, if it's low on freon, would that cause the "clutch" to stop spinning? another words would it be worth paying some cash to put freon in it?
geeez, this is rocket science...........
__________________
  #4 (permalink)
Old 05-13-2008, 12:38 PM
ErnieX is starting off with a positive reputation.
If the front plate of the compressor pulley is not spinning when the A/C is switched on then the compressor is not running. A low freon level will trigger the low pressure cut off switch and keep the comp. from turning on. This protects the comp. Since the system is a closed system, if your low on freon you have a leak. You need to take it to a professional and have it leak tested, repaired and recharged.
You could add freon to the system and see if the comp. comes on - this will probably require you to disconnect the low pressure switch so the compressor will run enough to accept the freon. If not repaired, any freon added will just leak out again.
Hope this helps some.
EE
  #5 (permalink)
Old 05-13-2008, 01:05 PM
jwford's Avatar
EE
thanks Ernie, yup---great explanation. gonna check it out when i get home.....
__________________
  #6 (permalink)
Old 05-13-2008, 07:34 PM
jwford's Avatar
well the comp is not spinning at all. hmmm, plan B.
i wonder if it's worth throwing Freon in?
__________________
  #7 (permalink)
Old 05-13-2008, 08:14 PM
The compressor protects itself from under and over pressure. Are you under or over? Do you have 12Vdc at the clutch coil? Is the ON/OFF switch good? Is the relay energizing to supply voltage to the compressor? Do you have a freon leak? These are only a few of the questions you have to be able to answer. There are more. I told you this ain't rocket science. First thing is a good DVOM and a schematic. You'll need these to answer these basic questions, but most of the time you can solve your problem with the correct answers to these questions. Oh, and by the way different manufacturers uses different systems so you have to know what system you're working with.
  #8 (permalink)
Old 05-13-2008, 10:13 PM
460's Avatar
460 460 is offline
Magician
460 is starting off with a positive reputation.
If I had to take a guess of all things that could be wrong, I would guess it's low on freon. Be sure to have dye added if you charge it so if the new freon leaks out you can find the leak easier.
  #9 (permalink)
Old 05-13-2008, 10:40 PM
jwford's Avatar
Quote:
yup---i'm takin the low bid for sure. i'll have to sweet talk my mechanic(aka the inspecter that should't inspect my truck--LEGALLY?) i'll ask him to tell me yey or ney if i'ts worth a ****.
__________________
  #10 (permalink)
Old 05-15-2008, 09:00 AM
freesplorer is starting off with a positive reputation.
Whats with you and Rocket Science.. I though this forum was to ask questions on stuff you don't know.. not get bashed for not knowing!!! SHEESH!!!
  #11 (permalink)
Old 05-15-2008, 10:28 AM
jwford's Avatar
no problem with Mr Rocket Scientists there. he came back with some good issue's to check out. for me, the amoeba looking up through the microscope lense, i was hopeing for a simpler solution. i don't have a shop with all the goodies to check everything out.
i'm better at sweet talking my mechanic, after visiting here anyway. gonna see what it'll cost me to:1-see if the compressor works and 2-if it's worth putting freon in.
i'll pony up a certain amount of bucks.....it's fixing to get sweltering hot down here in Houston Texas. and you know what i mean. that AIN'T rocket science.......---jw
__________________
  #12 (permalink)
Old 05-16-2008, 06:57 PM
billkean is starting off with a positive reputation.
Hello, I have a similar problem with my '93 Explorer xlt. The compressor does not engage when set to AC, but it does engage when set to defrost. I have not tested for freon pressure. If low, would this situation occur? Or is there another problem?
Please excuse if this post is not in the proper thread.
  #13 (permalink)
Old 05-16-2008, 10:50 PM
jwford's Avatar
yup---freon pressure does come into play. i'm checking mine out in June when i have to have my explorer inspected.......thus sweet talking my freekin yankee mechanic from the Bronx...... i always give him **** since i'm a south Texan. not to worry though---he keeps up with the Astros more than i do........damn yankee's and their baseball....
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
