1995 5.8 oil capacity
Old 08-22-1999, 04:29 PM
John Baker
Guest
Posts: n/a
I just purchased a 1995 F150 4x4 with a 5.8L motor.The owners guide says 6 qts. with filter.So,without question, I change the filter and put in 6qts.,start the truck,check for leaks,and then shut it off.When I checked the dipstick it read about 1 qt. over full.Her is my question,do you put in 6qts. or go by the dipstick and put in 5.25qts. to put it right on full?Thanks in advance for any input.
Old 08-22-1999, 07:03 PM
Pastmaster's Avatar
Pastmaster
Pastmaster is offline
John, when I change my oil in my 93, I always put the 6 qrts in, and it reads overfilled. you might try to put the 5.25 in and drive it a day and check it when the engine is cold again. Ill bet you need to fill the remainder in at that time!!!!
Old 08-22-1999, 08:14 PM
mandm's Avatar
mandm
mandm is offline
I believe the 4 wheel drive's all use 6 quarts. Go by the owner's manual. The filter holds a good part of a quart... and it's gotta fill up. Make sure it's on absolutly level ground. My F250 w/ 460 will read incorrectly if it's not perfecly level.
DM
Old 10-19-1999, 11:19 AM
slik's Avatar
slik
slik is offline
Old 09-18-2018, 01:55 PM
Tenaciousblue's Avatar
Tenaciousblue
Tenaciousblue is offline
Angry Oil way over dip stick full
I have a '95 F150 4X4 Xl 5.8. I got it back from shop and it was way overfill. I am taking it back to have them drain some off. Am I making a mistake? I have driven it
about 40 mi. since oil change and it's still way over. Will this condition blow any seals? Should I leave it alone?
Old 09-19-2018, 01:38 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
Too much oil will allow the crank to hit it, which not only wastes energy, but it can whip air into the oil, which makes it less effective at lubrication.
Old 09-19-2018, 02:25 PM
Tenaciousblue
Thumbs up To much oil in crankcase
You are right, I see it has happened to several others. I will only add 5 qts. and the run engine, check dipstick and add accordingly
, Thanks
dh_meyer
2009 - 2014 F150
18
06-01-2023 03:38 PM
tcr1016
03-23-2016 09:02 PM
pauleouellette
09-13-2015 10:46 PM
hillbillydaddy87
03-02-2009 09:02 AM
seebeew
Modular V8 (4.6L, 5.4L)
06-21-2003 04:05 PM
Quick Reply: 1995 5.8 oil capacity
