1995 5.8 oil capacity - Ford Truck Enthusiasts Forums
Old 08-22-1999, 05:29 PM
John Baker
Guest
Posts: n/a
I just purchased a 1995 F150 4x4 with a 5.8L motor.The owners guide says 6 qts. with filter.So,without question, I change the filter and put in 6qts.,start the truck,check for leaks,and then shut it off.When I checked the dipstick it read about 1 qt. over full.Her is my question,do you put in 6qts. or go by the dipstick and put in 5.25qts. to put it right on full?Thanks in advance for any input.
Old 08-22-1999, 08:03 PM
Pastmaster Pastmaster is offline
Pastmaster is starting off with a positive reputation.
John, when I change my oil in my 93, I always put the 6 qrts in, and it reads overfilled. you might try to put the 5.25 in and drive it a day and check it when the engine is cold again. Ill bet you need to fill the remainder in at that time!!!!
Old 08-22-1999, 09:14 PM
mandm mandm is offline
mandm is starting off with a positive reputation.
I believe the 4 wheel drive's all use 6 quarts. Go by the owner's manual. The filter holds a good part of a quart... and it's gotta fill up. Make sure it's on absolutly level ground. My F250 w/ 460 will read incorrectly if it's not perfecly level.
DM
Old 10-19-1999, 12:19 PM
slik slik is offline
slik is starting off with a positive reputation.
How accurate is oil dipstick on 2012 5.0 ? dh_meyer 2009 - 2014 F150 17 11-06-2016 07:48 AM
Actual 4.2 Engine Oil Capacity on 2000 E-150?? tcr1016 1968-2013 Full Size Vans 2 03-23-2016 10:02 PM
Oil Capacity for my truck pickenspolitics 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-09-2015 09:48 PM
Oil Quantity Truckpilot1329 2009 - 2014 F150 10 10-24-2014 02:09 PM
1995 5.0L Engine Oil Capacity DTrain Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 01-20-2004 06:02 PM
Tags
1995, 351, 4x4, 58, 58l, 93, 95, capacity, engine, f150, f250, ford, oil, quarts, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
