Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 09:19 PM
RP27G8G is starting off with a positive reputation.
FIPL valve/sensor
A while back I posted I didn't have a kickdown on my 91 F 250 7.3 with the E4OD. Someone mentioned I needed to adjust or replace the FIPL valve/sensor. What is it?? I can't find it mentioned anywhere in the Ford factory manuals. Is it the same as the Throttle Position Sensor (TPS)?
Thanks in advance.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-12-2008, 09:54 PM
mdacton is starting off with a positive reputation.
yeah same as tps.
I had the same problem, it was the nutral safety switch and corosion in the trans plug to the solenoid pack.
__________________
93 F-250 7.3L idi, E40D, 4x4, ext. cab long bed, 3.55 gears. Stock
  #3 (permalink)
Old 05-12-2008, 10:06 PM
Was your neutral safety switch bad? We unhooked the TPS and the truck ran/shifted GREAT! It has never run that good since I got it but still no kick down.
  #4 (permalink)
Old 05-12-2008, 10:44 PM
ford trans tech is starting off with a positive reputation.
i believe you unhooked something other than the fipl , if it were disconnected the shifts would be extremely delayed
the neutral safety switch is the transmission range sensor it only sends gear selector lever position to the processor and has no input on down shifting
however if it is bad the vehicle can have gear hunting
__________________
89 F-350 CREWCAB DUALLY
  #5 (permalink)
Old 05-13-2008, 05:55 PM
I replaced the TPS and no difference. I had the old one checked and it checked good. Now where do I start searching??? I'm not sure why I mentioned the neutral safety switch in my last post. We never touched that. Is it possible the TPS isn't getting any power? HELP!!
  #6 (permalink)
Old 05-13-2008, 09:50 PM
George D.'s Avatar
George D. is starting off with a positive reputation.
Have you tryed adjusting it? with a warm engine slide a paperclip into the center wire and hook a volt meter to it and to ground you should have 1.1v closed throtle and a minimum of 3.v wide open throtle and no more than 4.3v wide open throtle.
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
  #7 (permalink)
Old 05-13-2008, 10:46 PM
Adjust it by loosening the two screws and moving it on it's axis? That's the only way I see to adjust it.
Thanks!
  #8 (permalink)
Old 05-14-2008, 12:08 AM
George D.'s Avatar
Yeah try the smaller torx screws first.
__________________
  #9 (permalink)
Old 05-14-2008, 06:43 AM
The smaller torx screw only hold the sensor on. The larger phillips head screws loosen the mount that lets it turn to the right or left.
Thanks!
  #10 (permalink)
Old 05-14-2008, 11:01 AM
it should have larger torx screws holding the plate to the IP
the bolts are special shouldered bolts
if someone has replaced them with standard bolts or screws then the sensor cannot be adjusted correctly because it cannot center on the IP shaft
__________________
  #11 (permalink)
Old 05-14-2008, 06:23 PM
Looks like that's a place to start. I guess I need to go to the dealer to get new ones?
  #12 (permalink)
Old 05-14-2008, 06:49 PM
George D.'s Avatar
The small torx screws do alow some adjustment but it sounds like you may have found your problem.
__________________
  #13 (permalink)
Old 05-18-2008, 01:19 AM
Well, still no good results. I tested the voltage at the FIPL and th etransmission. One side of the three pin connector at the FIPL had 4.93 volts. The others had very negligible at a setting of 200m. I tested th connection at the trans and it is getting 14 volts on one side and 4.93 on the other. Any ide3a where I go from here?
Thanks in advance.
  #14 (permalink)
Old 05-18-2008, 08:02 AM
PLC7.3 is starting off with a positive reputation.
Are you getting a code set .......... visit Azone or some other AP store that can do a code test for you....... Free
Click on my name and email me..... I will forward info re codes etc.
__________________
93 F250 SC 4x4 E4OD 355LS
  #15 (permalink)
Old 05-19-2008, 08:52 AM
bleedin blue is starting off with a positive reputation.
did you disconnect the batteries to clear any faults?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
