Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Modular V10
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 09:17 PM
saggys is starting off with a positive reputation.
Shift improving kit for 99 V-10
Looking for a shift improvement kit for my 99 F350 V-10. It has a 4r100 tranny with 4.30 gears and will be used to haul my 4,000lb truck camper and pull a 3,500 lb boat.Tranny and truck have 67,000 miles on it and all is OK, but wished the tranny shifted a little crisper from 2nd to 3rd. No programmers please, want to do this manually.
  #2 (permalink)
Old 05-12-2008, 10:24 PM
S.A.L. is starting off with a positive reputation.
You'll want to get an accumulator.
They're about $225 for a preassembled unit
They're also called Valve bodies.
It's a do it yourself job that takes about a half hour.
It's the best mod for the money. You'll smile everytime it shifts.
  #3 (permalink)
Old 05-12-2008, 10:26 PM
Monster-4 is starting off with a positive reputation.
Might want to take a look at this.
Factory Tech Valve Body
__________________
2000 F-250 SC 4X4 Shortbed Lariat 6.8L V10
  #4 (permalink)
Old 05-12-2008, 10:45 PM
I've got the FTVB.
It is the original for this box.
  #5 (permalink)
Old 05-13-2008, 09:01 AM
dkf's Avatar
dkf dkf is offline
dkf is gaining momentum as a positive member of FTE.
I have the factory tech 2C accumulator also. It works very well and provides very firm shifts. Its a must if you tow. The FT accumulator can be used with a tuner (I am right now) just leave the trans firmness stock.
  #6 (permalink)
Old 05-13-2008, 10:50 AM
chris60 is starting off with a positive reputation.
So does no one use the programmer at all? I have read the attachments & understand the logic, My superchip 1715 has 5 settings, & for the 1-2 shift I have set it at the 3rd level, & the others I have set at 2 out of 5. I do tow as well, and know am wondering if I should set it back to stock, & get this shift kit. I have talked to a tranny shop, they thought that my settings would improve the life of my tranny overall, vs leaving it stock .
  #7 (permalink)
Old 05-13-2008, 11:17 AM
dkf's Avatar
dkf dkf is offline
A tuner increases line pressure during the shift to increase firmness. To some extent it may make the trans last longer but by upping the line pressure it is harder on the pump. The FT accumulator doesn't up line pressure like a tuner does, line pressures are very similar to stock with the FT accumulator.
Read more about it here. 1997-2004 E4OD/ 4R100 Gas Valve Body / Lightning
  #8 (permalink)
Old 05-13-2008, 12:02 PM
thanks, I guess the FT accumulator is the way to go.. Sure is easy to spend money on our toys.. thats the next project.
  #9 (permalink)
Old 05-13-2008, 04:19 PM
Here ya go. From the horses mouth, so to speak.
This is around 5 years ago.
By Gregg Evans
Developer of the Factory Tech Accumulator
I see a lot of questions about Shift Kits, Line Modulator Boost Valves and Accumulators. As a transmission repairman I’d like to share my thoughts on the subject.
What most people are looking for in transmission strategy is a quicker, firmer shift, or more technically a shorter shift duration. Shift duration is how long it takes for a shift to occur, or the amount of time that the clutches are slipping. A shorter shift duration has a performance feel, and generally is better for the clutches, because the wear on the plates happens during this “slip”. Shortening duration also will reduce heat, which is responsible for most automatic transmission failures. The way to reduce shift duration is to increase the engagement pressure of fluid to the clutch during the shift.
One way to increase pressure in an electronically controlled automatic is to have the PCM (or an aftermarket chip) command the EPC (electronic Pressure Control Solenoid) to increase pressure. Doing this will give the desired result, but at a cost. Many systems could in theory raise and maintain Line Pressure at the expense of either the Lubrication circuit or overworking the pump assembly. By the time symptoms appear of the damage this can do, the damage is done and the repairs can be very expensive. If the lube circuit is starved in order to maintain pressure to the accumulator, the first obvious indication could be when the output shaft welds itself to the rear case bushing, a catastrophic failure that would essentially destroy the transmission. If you have a chip that raises Line Pressure above the factory settings, make sure your tuner has made provisions to avoid this. Also, some transmissions that have used software to raise Line Pressure have shown longer term (12-18 months) damage to the pump assembly caused by the extra load placed on the pump.
The alternative to raising Line Pressure with software is to use a mechanical “shift kit” to raise Modulated Pressure or more simply, a set of valves and springs in the accumulator valve body. The term “Shift Kit” is a trademark of a transmission aftermarket company, so I avoid using it when I can. Since the accumulator is hydraulically “downstream” of the EPC, a mechanical shift kit does not interrupt any lubrication failsafes and since it is using modulated pressure boost (through the Line Modulator Boost Valve) it does not place any additional load on the pump. I have seen 3 basic variations of mechanical shift improvers, a “Line Pressure Mod Valve” ($89-$99), a “3 springs and a valve (about $150, basically a Line Mod Valve and 3 additional springs) and a full accumulator ($225, a Line mod valve, springs, lower control springs and lower control valves installed into a new or rebuilt accumulator valve body). I’m not going to be coy about it, I designed, build and indirectly sell the Factory Tech Accumulator, so instead of trying to act neutral (I’m not) I’ll tell you why I think the kit I build is a better kit, a better value and better for your transmission.
First, an accumulator is a fairly straightforward assembly. In the 4R100, there are 3 shift bores, and 1 line pressure/throttle bore. The 3 shift bores are identical, and different springs are set in them to control the reaction of the accumulator piston to hydraulic pressure, this reaction translates into shift duration on the shift controlled by that bore. All of the bores are fed pressure by the Line Modulator Boost Valve, which reacts to the Throttle Valve, controlling this circuit boosts line pressure into all of the shift bores. If you change the Line Modulator Boost Valve and raise line pressure throughout the body, the individual shift bores are no longer “tuned” properly and the reaction in the shift bores will be out of calibration for the elevated line pressure. For this reason, you need to recalibrate the shift bores, both in the top circuit (above the accumulator piston) and below (the 321-310 circuit). Also, in the 2001 model Lightings, I have found that increased pressure in the lower circuits caused the 321 valves to “side load” or bind up due to asymmetric application of hydraulic pressure during the shift, resulting in a “bang shift”. A Line Mod valve fails to address these conditions. My last (but not least) concern with a Line Mod valve is cost, I don’t think you get much bang for the buck if you pay $89 for a Line Modulator Boost Valve. I’ve been very upfront about this, I use a part very similar to this as part of the Factory Tech/PSP Accumulator. In many ways, I think the part I use is higher quality, my valve and sleeve are made from stainless steel and most of the other ones I see have aluminum sleeves. This can cause problems in the long run too, as the steel valve cycles though an aluminum sleeve, the sleeve wears faster than the valve and after a time this results in pressure loss and sloppy shifts, the condition the part is designed to correct. Also, unlike most of the parts I have personally seen, I use an O-Ring seal to prevent pressure leaking out of the circuit. For all this, my cost for the valve is about $20, if you just want a boost valve, email me, I’ll sell you one for $30, shipping included, and in a year I’ll still be here if you need a new transmission, my Monster Box goes for $1995.
The second popular option is the 3 springs and a valve shift kits. Using this type of kit recalibrates the upper circuits to the elevated line pressure, but still ignores the side loading of the lower control valves. The kit of this type that I have seen also uses an aluminum sleeve/steel valve, and again, the cost is high, for the extra $50 give or take, you get 3 springs and more detailed instructions.
For the Factory Tech Accumulator Shift Kit, I start with a new Accumulator Valve body, Genuine Ford Part (F81Z-7G422-AA, List Price at your dealer is $165 +/-), I add a Line Modulator Boost Valve (about $20), recalibrate the upper circuit with different springs ($12) and upgrade the lower circuit springs and use a valve designed to cycle more freely in the bore to prevent both side loading and binding. (I won’t tell you the price, a guy has to have a few secrets). My lower circuit “310” valve is designed to preload the clutch at less than line pressure, taking the variability out of the shift control. Although it looks very much like the kits available elsewhere, the control of the shift is much more precisely controlled this way, acconting for the much beter performance you get from a Factory Tech Accumulator. My point is, I’ve heard from quite few people who bought the other kits and asked themselves (and me) “Is this it?, I paid $XXXX for this?” I honestly hope that no-one ever got one of my kits and asked that question. The fact is, the final retail price of the Factory Tech Accumulator is less than the list price of the components that go into it, and my distributors makes a profit, too.
And finally, I have my reputation. Read the “mods” on bulletin boards to see who my customers are, do a search for Factory Tech, and after you see who they are, E-Mail them and ask how they like the kit. As of this writing, I’ve sold or given away (for the first year I made them for people I work and didn’t even charge them above what I paid for parts) about 2000 accumulators and exactly one customer has let me know he wasn’t satisfied, and in the end I even satisfied him. (he had installation issues, after the part was in right, he loved it). When the ‘01 Lightings first came out, the side loading issues on the lower circuit became evident, and I replaced 2 units after I redesigned the accumulator. Other than these cases, I know of NO customers who have had complaints about my parts. Just consider this, if you buy XXX parts, and have a problem, what’s the chance of you getting the home number of the guy who designed it? If you bought it used off of E-Bay? If you have one of my parts and you have a problem, I’ll fix it. That means if it needs to be replaced, you get a new one, no matter where you got it, it means that if you have a question about installation or performance that you can’t get a good answer to, you can get in touch with me and if I need to talk to you to make it clear, I’ll send you my home number, or call you. There is no-one selling parts for Lightnings that has built more 4R100s than me, I know this box and I stand behind what I build, because I want to sell you that Monster Box when you want it, when you’re ready for it, not when you grenade the tranny and need it.
Thanks,
Gregg Evans
  #10 (permalink)
Old 05-13-2008, 08:09 PM
Skoda is starting off with a positive reputation.
By Gregg Evans
Thanks,
Gregg Evans
When it come time to put int some elbow grease on my tranny you'll be the first I get in touch with I have a problem Of finding garage's that are willing to do the work for my money but after 4 months some thing they have touched has failed, and yet won't back what they've done
look forward to hearing from you in the near future
Skoda
__________________
99 F-250 Lariat V10
***Looking for a black grill 05-07 some nicks and scratchs exceptable***
05 upper bumper valence
Tow mirrors
05 Head lights
Ebay Headers
SCT LiveWire from 5 star tunning
Dual 16" coolling fans
Top end rebuild
ARP head studs
  #11 (permalink)
Old 05-14-2008, 03:31 AM
skipperw is starting off with a positive reputation.
I love hearing the the Toyos chirp when I go from 2nd to 3rd gear WOT.
__________________
Silver Son
Whipple Supercharger
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
