Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 08:52 PM
z1121jack is starting off with a positive reputation.
harmonic balancer and serpentine belts
I am changing my 351 {'85) to a serpentine belt. I know that all the front end parts need to be changed. But, my parts are from a 302. I'm not sure if 302 harmonic balancer will be correct for a 351.
any pointers will be appreciated.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-13-2008, 11:51 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Since the deck height is higer on the 351, you may find you need a longer belt when you're all done.
As for 351 vs. 302 balancer, my gut reaction would be 'no way'. Well, my gut was right. Two diff. part numbers here, can't imagine it would be different elsewhere:
Shop for Ford F-Series Pickup Harmonic Balancer at 1A AutoŽ
  #3 (permalink)
Old 05-14-2008, 08:05 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Don't change your harmonic balancer, just bolt the crank pulley from the 302 on it.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #4 (permalink)
Old 05-14-2008, 12:44 PM
thanks
8ill look for a 351 balancer
  #5 (permalink)
Old 05-14-2008, 02:02 PM
Conanski's Avatar
Quote:
Originally Posted by z1121jack View Post
thanks ill look for a 351 balancer
I think you misunderstand, the balancer and pully are seperate parts, you should be able to remove the pulley from your 302 and install it on the 351 without touching the harmonic balancer on either motor.
__________________
Paul O
  #6 (permalink)
Old 05-14-2008, 05:00 PM
io knew they were seperate parts I just goofed.misspoke I'll use my 351 balancer.
  #7 (permalink)
Old 05-14-2008, 10:15 PM
Social Outcast
petes79f150 has a good reputation on FTE.petes79f150 has a good reputation on FTE.
The offsets are different, if you're going to a serp from a v-belt. You need to make sure the accessory drives line up. Spacers are available.
Pete
__________________
The Hurrier I Go, The Behinder I Get.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
