Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 08:32 PM
KyleG is starting off with a positive reputation.
Exclamation Timing my injection pump...
Well I took my injection pump out and was cleaning everything up, and i was under my hood while my buddy was playin with somethin....ends up it was the pump...he was randomly turning the pump and wasnt counting how many times he turned it, and i have no idea how to time the pump back to the engine....any help?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-12-2008, 08:39 PM
Karl Keicher's Avatar
Karl Keicher is starting off with a positive reputation.
Dont worry about it- the drive on the pump can only go on one way and when it is installed will work properly. Use the factory timing marks to in stall the pump ( the mark on the pump housing to the mark on the mounting housing) Then have your local dealer hook it up and set the static timing and you should be good to go.
__________________
It's all good!
I wont be wronged, I wont be insulted, and I wont be laid a hand on-I dont do these things to other people and I require the same from them! jw
'04 F-250 Super Duty PSD
'03 Cadillac DeVille 32valve northstar
'79 F-150 Recently acquired project
'03 Kenworth T-600
  #3 (permalink)
Old 05-12-2008, 09:37 PM
is it possible to time the engine myself, or do i have to take it to a dealer
  #4 (permalink)
Old 05-12-2008, 09:46 PM
You can do the initial timing your self by lining up the factory marks, and chances are you will be good, however it's a good idea to have a dealer check it out to make sure the timing is right so as to avoid a detonation or pre-ignition problem which could lead to more serious problems. Shouldnt cost a whole lot- they just put a probe in the timing marker and connect to the number one cylinder and if the timing is right your good to go, if not, its a quick adjustment.
__________________
It's all good!
'03 Kenworth T-600
  #5 (permalink)
Old 05-12-2008, 10:24 PM
How about this? I got my marks as close as I could, but the truck wont stay running. It starts for a second and revs to about 2000 and just cuts right out. my mark is about 4 lines off, will that make that much of a difference in the timing?
  #6 (permalink)
Old 05-12-2008, 10:40 PM
David85 is gaining momentum as a positive member of FTE.
I think you still have air in the fuel system. How much run time did you get since the pump was put back in? It usually sputteres and surges a little when I fire mine up after draining the IP.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #7 (permalink)
Old 05-12-2008, 11:50 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
4 lines off the factory marks?
To which side?
Top of the IP toward the passenger side is advance.
Both lines should be right in line, or IP mark slightly to the passenger side of the drive gear cover mark.
You did remove the IP from the drive gear cover leaving the drive gear splined to the cam gear, right?
Good luck with finding a dealer that still has the IDI timing meter and a mechanic that knows how to use it.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
www.ford-trucks.com/guidelines.html
FTE Moderator in the IDI diesel forum.
WV Chapter Member
  #8 (permalink)
Old 05-13-2008, 12:48 AM
bigbubba87's Avatar
bigbubba87 is starting off with a positive reputation.
i did the same thing only i took mine off to put a gear housing on it with a tach sensor. i also turned the fuel screw in one flat and put it all together and now it runs but misses. it dosent smoke at all or anything else just misses. Any ideas? did i turn the fuel up to much? i did not take the gear off the motor so i know the gear didnt get messed up.
__________________
87 f250 6.9 c6 4x4 4" lift 33s flat bed all LED lights,73 f250 390 4sp 4x4 36s canvas topped bed
  #9 (permalink)
Old 05-13-2008, 06:20 AM
Dave, I took the pump out but did not mess with the gear or turn it or anything, it was just the injection pump that was turned when it was out of the truck...and the timing marks are off to the driver side, I am trying to find a way to turn the pump to get it timed up.
  #10 (permalink)
Old 05-13-2008, 09:28 PM
There are a couple bolt holes on the drivers side of the IP.
They are there to mount the VRV or FILP sensor on automatic trucks.
Since I don't have the fancy tool, I made one out of 3/4" angle iron about 16" long.
I drilled a couple holes in the angle so I could screw short bolts into the IP holes.
After the angle is mounted, loosen the IP bolts, grab the angle and you can get just about any amount of movement in either direction you want.
Makes moving small amounts, then holding in position till a bolt is tight so much easier.
Lines should be dead on in line for the correct static timing.
With the IP and injectors I have now, I have the IP line about 3/32" to the passenger side of the gear cover line.
Nice rattle when the cold timing advance is on, almost a slight rattle after it kicks off.
All traces of rattle are gone as soon as I give it any throttle at all.
Starts good, power is good.
That setting may be a little hot for a stock IP though, mine has several non stock adjustments inside the IP.
Normal rule is rattle when the advance is on, no rattle when the advance is off.
If you set yours that way, it will probably be as good or better than most mechanics will get it set.
You can always play with the setting, IP and injector condition do play a factor in how much advance the engine is happy with.
__________________
"I dig dirt"
WV Chapter Member
  #11 (permalink)
Old 05-15-2008, 02:44 PM
Well I got the truck running, but i have some adjustments to make, because my power is not constant. I can be goin up the road at 60 mph, and it will randomly bogg down through all gears and eventually stall out...after a few seconds of turning it over it runs again, sketchy, but it runs, smooths out with full power and a few seconds later it does the same?????? It feels like it is starving for fuel, but i am running regular diesel in it not bio. I just dont know
  #12 (permalink)
Old 05-15-2008, 08:27 PM
Sounds like a fuel supply problem.
When it stalls, if you remove the fuel cap of the tank you are running on, does it sound like their is a vacuum in the tank?
What year is your truck?
__________________
"I dig dirt"
WV Chapter Member
  #13 (permalink)
Old 05-15-2008, 11:50 PM
My truck is an 86 with a 6.9, I added a turbo and turned the pump up before I was running on bio...but the way I make my fuel may not be the right way for my older style pump, i should have done some research before hand, even though the pump is not the original one. I talked to a guy from an injection shop about my problem, and he said that there is a fitting on top of my pump on my return line that has a little glass ball-like regulator in it, that could be bad or my primary advance is bad in my pump just from running the fuel that I was running in it.
The way i make my fuel is the same exact way a buddy of mine runs in his powerstroke, now i know they have more fuel heaters and such, but I just thin mine up more, and i dont see why his runs good on it and mine quit so soon?? He is running his on 40,000 miles on the fuel and still runs good and mine quit at 500. so i guess i will do more investigating and mess with my timing more and buy one of those fittings before sending my pump out to be rebuilt.
  #14 (permalink)
Old 05-16-2008, 07:28 PM
Some of the old original IP's have more rubber parts in them.
Rubber and biodiesel are not good friends.
Remove the return line fitting on top of the IP, if you see black chunks of rubber the flex ring is done for, you need a new IP.
On the 86, there are tank vents in the top of the tank.
The vents have small rubber vent lines that are supposed to be clipped to the frame or cross member above the tank.
I have seen them blocked with mud, which then creates a vacuum in the tank.
Your problem could be chunks in the return line blocking it off at the return fitting, that causes to much fuel pressure in the IP which will kill the engine.
It could also be the vent line blocked, which will run the engine out of fuel.
Both ways it acts almost the same way when it quites.
Power just keeps dropping off till the engine stalls.
__________________
"I dig dirt"
WV Chapter Member
  #15 (permalink)
Old 05-17-2008, 11:03 AM
well you should know that my IP is not the factory one, it is an aluminum pump that was replaced a number of years ago.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
