Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 08:29 PM
twisted limb is starting off with a positive reputation.
clunk when breaking
I put right side ball joints on my 93'(first time I tried this job and hopefully the last) and all seemed to go well and I don't think I screwed anything up, but now when I get on the breaks and stop alittle hard I hear a clunk.It is hard to tell where it is coming from.Gradual breaking does not make it do it.Problem was not there before ball joint job.Not sure if having a tight front end is revealing something else now that has wear?Sound kind of remines me of when my radius arm bracket and bushing went bad.Any thoughts?
  #2 (permalink)
Old 05-12-2008, 09:28 PM
b4hntn is starting off with a positive reputation.
Grease the slip joint in the middle of the rear driveshaft.
__________________
FTE is great! Be a supporter to keep this forum going. 94 5.8 EB, 460 air inlet tube, K & N drop in, MSD Blaster, 9 mm Ford Racing Wires, mechanical oil and temp guages and the rest all stock.
  #3 (permalink)
Old 05-12-2008, 10:06 PM
cajunland is starting off with a positive reputation.
Sounds like your radius arm bushings. I assume you changed them too. Doulble check that they are tighten to proper torque specs.
__________________
Tim
'93 Bronco - 302; E4OD; 4in ProComp, 35" Rem. Mud Brute
  #4 (permalink)
Old 05-13-2008, 05:15 AM
Greased slip joint in past when it was clunking and yes bracket and bushings were replaced.
  #5 (permalink)
Old 05-13-2008, 05:56 AM
Hmmm....I'm sure more suggestions will come along.
__________________
  #6 (permalink)
Old 05-13-2008, 08:41 AM
alxsnmr is starting off with a positive reputation.
Check the U-joints?
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, otherwise still stock.
  #7 (permalink)
Old 05-13-2008, 02:22 PM
I will.Just odd that no clunk before the ball joint job?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
