Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 08:03 PM
ihateminimumwage's Avatar
ihateminimumwage has a good reputation on FTE.ihateminimumwage has a good reputation on FTE.ihateminimumwage has a good reputation on FTE.
62 Cruise-O-Matic - Won't shift to 3rd Gear
I went out of town for a week, and let my ol' lady drive my 62 Thunderbird. It was running great the whole time, but when I got back to town it started overheating. Turns out were some pinhole leaks in the radiator, Drove it a bit around town, and then parked yesterday. Messed with the radiator to get it to stop leaking, put it all back together and drove to work today.
I suddenly don't have 3rd gear. Shifts fine through 1-2, but just won't even try to hit 3rd. I checked the vacuum line going to the modulator with a vacuum gauge, and it read a steady 15 at idle, the same as the motor. I'm hoping my modulator is just shot, because I'm far from having the money for a rebuild. Anything else I should be checking for?
__________________
Taylor
73 F250 4x4 XLT 400 C6 NP205
62 Thunderbird 390
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-12-2008, 08:28 PM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
The valve is C1AZ-7A377-A (Motorcraft TM-1)
__________________
Bill / Retired Ford Partsman ~ 1962/97
Part number research: Trucks 1948/02 / Cars 1949/91
1963 Galaxie 500XL / 1965 F100 Styleside / 2008 Fusion
  #3 (permalink)
Old 05-12-2008, 09:31 PM
Thanks ND. I called one of the local parts shops, and I think the kid was looking up the wrong part. He said he'd have to order it, and it would be $41! I called the Kragen down the street, and they have it in stock for $7.99. Screw in, blue stripe, sounds like the one in my hand. I'm going to go check on it tomorrow.
I just pulled the old modulator, when I push the rod in, it pumps fine. The fluid that came out was pink and looked great, not burnt or discolored whatsoever...
__________________
Taylor
62 Thunderbird 390
  #4 (permalink)
Old 05-13-2008, 08:50 AM
stuart1 is gaining momentum as a positive member of FTE.
Same answer.
See you in the "other" forum.
Stu
__________________
Transmission builder since 1964.
2002 Ranger.
3.0 engine.
  #5 (permalink)
Old 05-13-2008, 12:11 PM
Lazy K is starting off with a positive reputation.
Here`s what my book says- defective governor, valve body needs cleaning, rear clutch defective, leakage in hydraulic system or fluid distributor sleeve in output shaft defective. Good luck.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
