AC problem again replaced rear evap core, and accumulator but still no cold a/c after re-charge.Clutch on compressor fine no leaks no but still only small cooling from A/C.Blend door okay too
Air temp seems to be related that is blows colder if the air outside is colder.
Pressure high side and low side seem fine and within standards.
Any Ideas Condenser Maybe?
I'm not sure what is going on!!
I do still have a hissing sound from rear quarter panel and when i put my hand around the rear evap core it seems like it's leaking but dye does not spit out under uv light.
Any Ideas guys, i really don't want to take this sucker in the shop.It will be a billion dollars!!
