Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 07:35 PM
zarillus is starting off with a positive reputation.
Exclamation Now i'm really confused!!! AC problems
AC problem again replaced rear evap core, and accumulator but still no cold a/c after re-charge.Clutch on compressor fine no leaks no but still only small cooling from A/C.Blend door okay too
Air temp seems to be related that is blows colder if the air outside is colder.
Pressure high side and low side seem fine and within standards.
Any Ideas Condenser Maybe?
I'm not sure what is going on!!
I do still have a hissing sound from rear quarter panel and when i put my hand around the rear evap core it seems like it's leaking but dye does not spit out under uv light.
Any Ideas guys, i really don't want to take this sucker in the shop.It will be a billion dollars!!
__________________
  #2 (permalink)
Old 05-12-2008, 09:37 PM
sbclemens is starting off with a positive reputation.
You can try putting some dye in the system and look for leaks. Is the front air cold? What is the temperature of the incoming air in the front compared with the out side air? What are your low and high side pressures?
__________________
98 Expy XLT 4x4 5.4L
  #3 (permalink)
Old 05-12-2008, 09:39 PM
Try putting some dye in the system and check for leaks. Does the front blow cold? What is the temperature of the incoming air in the front compared with the outside air? What are your high/low side pressures?
__________________
  #4 (permalink)
Old 05-13-2008, 06:10 AM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
What year?
What were the actual pressure readings, the ambient temp, and did you follow proper vehicle preparation?
Have you checked the fan clutch? Hit the condenser with the garden hose sprayer to see how it reacts?
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #5 (permalink)
Old 05-15-2008, 02:36 PM
45psi low & 300psi high
Ambient 80 degrees
Clutch operates fine
__________________
  #6 (permalink)
Old 05-15-2008, 02:56 PM
Quote:
Ambient 80 degrees
Those pressures are wacked. With an 80F ambient (assuming no other faults), you should be seeing low side pressures down in the upper 20s and a high side pressure much closer to 200.
Investigate:
1) Overcharge.
2) Restriction in high side including the condenser
3) Dirty condenser or insufficient airflow through condenser (weak fan clutch).
I'd say either #1 or #3 is the most likely.
Steve
__________________
  #7 (permalink)
Old 05-15-2008, 02:58 PM
dillinger is starting off with a positive reputation.
It's ALL about HEAT and TEMPERATURE!
This might help you out, a little long but alot of information.
I would almost say overcharge or a restriction.
__________________
2000 Ford Expedition 4.6L 2WD
1998 Ford Explorer XLT 4.0l 2WD
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
