351W to C-6 transmission - Ford Truck Enthusiasts Forums
Old 10-10-1999, 01:32 PM
Frank Frank is offline
Frank is starting off with a positive reputation.
Anyone have any experience with a 351W EFI to a C-6 transmission? Someone told me that only a E40D transmission will work. I'm hoping that the C-6 will work. I sure that I will have to get a new flexplate and probably a new wiring harness. Any suggestions? Thanks
Old 10-10-1999, 11:31 PM
Superdave Superdave is offline
Superdave is starting off with a positive reputation.
88 Fords had the fuel injected 351W with the C-6 transmission in big Broncos, F150's 4X4's, I don't know about 2 wheel drives though.
Old 10-11-1999, 12:29 AM
BigBrownTruck BigBrownTruck is offline
BigBrownTruck is starting off with a positive reputation.
I put a "small block C6" behind an 1980 302 in a 76 F100. The bell housing should be the same on your 351W. I believe that Small block C6s came in a lot of 80's vintage Vans w/ 302, 351W and also I found my Flexplate from a 73 Cougar that I think had a 351C. I've been told that the balance counterweight on 351W stayed 28oz until the end of it's production whereas the 302 (5.0) changed in the middle of the 80's to a 50 oz counterweight. I did have to relocate my transmission crossmember back a couple of inches but that was just a matter of having a couple of holes drilled. I also had to have my driveline shortened and a different end put on it. Beware, there are many C6's for big blocks with different bellhousing patterns.
Old 01-14-2000, 08:22 PM
tazfords's Avatar
tazfords tazfords is offline
tazfords is starting off with a positive reputation.
Better check on 302 and 351W being same at the bell housing . I don,t think so. 260,289,302 are the same. 351W is different bolt pattern . 351W will work with the correct C6 tranny.Don't have to be AOD.
Old 01-20-2000, 07:11 AM
Eric_B Eric_B is offline
Eric_B is starting off with a positive reputation.
>be AOD.
The 260 and the early 289s (first half year run) had a five bolt bell housing. Since then all 289s, 302s, 351Ws, 351Cs, and 300/240s have run the same 6 bolt bellhousing bolt pattern. There were at least two bellhousing though one to clear the smaller flexplates and one to clear the 351Cs and 351Ws on the C-4s. I believe all C-6s had the room in the bell to clear the larger flexplate. Not sure on that part though.
Old 01-24-2000, 04:40 PM
Bert Bert is offline
Bert is starting off with a positive reputation.
351w swap into 79 f150 4x4 m79fordtruck 1973 - 1979 F-100 & Larger F-Series Trucks 6 02-21-2013 10:42 PM
351W C6 swap help dranger33 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 01-04-2012 09:16 PM
c6 bolt patterns truckerboy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 04-13-2010 05:07 PM
Transmission Question mblatz 1973 - 1979 F-100 & Larger F-Series Trucks 0 04-22-2009 06:08 PM
C6 Transmission Skylift 4x4 1978 - 1996 Big Bronco 1 10-05-2003 03:00 PM
Tags
302, 351, 351w, 6b, 87, bellhousing, bolt, bronco, c6, f150, flexplate, ford, original, pattern, trans, transmission, transmissions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
