Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-12-2008, 05:29 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Koh
did a search on this site for KOH, came up empty. where is the cheapest place to get it? AAA chemical has 2 pounds for $11.99, how much methoxide would 2 pounds make? thanks
Finally found someone who is wanting to get into this as much as me, so am getting things together, hopefully build a small 5 gallon processor this weekend.
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #2 (permalink)
Old 05-14-2008, 12:19 AM
blkbeast blkbeast is offline
Garage is empty, add now
blkbeast is starting off with a positive reputation.
I am still in the process of making my first 25 gal batch, but everything i've read leads me to believe that depending on what your wvo titrates at 2lbs of KOH should be close to making 5gals of methoxide which should make 25gals of BD. The base number for KOH is 7grams per liter of oil, then you add to that whatever your oil titrates at to find out how much KOH to add. My oil titrated at 2ml. So I took the base of 7grams per liter added my 2 to make 9grams per liter. Then after looking at conversion charts I found online I found that for a 25gal batch I needed 1.9xxx pounds of KOH so I just used 2lbs since I got my KOH in 2lb containers.
I got my KOH online from Camden Grey and paid around $4.60 a pound including shipping. I've since seen it on Utah Biodiesel Supply - Biodiesel Homebrewing Supplies, Equipment, Processors and Information for about half that if you buy 55lbs. But like I said I'm just beginning to make my own BD so don't take my advice as gospel because I could be wrong and if I am I'm sure one of the seasoned brewers here will pipe in and say so, which in turn will teach me something too.
  #3 (permalink)
Old 05-14-2008, 12:26 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Wow! 4-5 dollars per pound!!!!!!!!!!!
I buy mine from a local chemical supplier for $61 for a 50lb bag.............
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #4 (permalink)
Old 05-14-2008, 01:45 PM
Gun-Driver's Avatar
Gun-Driver Gun-Driver is offline
Gun-Driver is starting off with a positive reputation.
I'm with Fabman on this one, way to much. I was paying $50.00 for a fifty lb. bag, Iwas just told that the price is going up to $75.00 per 50lbs., but thats still only $1.50 a pound.
I would call around to some of the chemical distributors in your area.
  #5 (permalink)
Old 05-14-2008, 01:57 PM
I've called every chemical supplier within 50 miles and nobody carries it or showed any interest in getting it. Half the places I talked to didn't even know what it was. I called a plant that makes soap and they don't sell raw ingredients and didn't know where they got their ingredients from. I need to call them back and dig a little deeper into where they get their supplies. Looks like some of us have no choice but to either drive a couple hours to get it, or pay the extra and order it online.
  #6 (permalink)
Old 05-14-2008, 02:33 PM
Rushmore X's Avatar
2003 Ford Excursion
Sounds like the price that I got from the local chemical company yesterday of $68 for 50 lbs isn't too bad. I had hopes of getting smaller ammounts such as 2 lbs for the 1st couple batches though. might just have to get those online. thanks guys.
__________________
  #7 (permalink)
Old 05-16-2008, 06:08 PM
Wieckster Wieckster is offline
Wieckster is starting off with a positive reputation.
I pay 75.00 for a 50 # bag
__________________
CHAD
2001 F250 4x4 Lariet Extended Cab,Kwik Filter,5" Exhaust Straight-piped,Auto Meter Gauges,285's,WW,CCV,BlueCPS,Remote Start/W
alarm,8.2 BOSS VXT-Plow,Cool Pipes,Bilstein shocks,203 t-stat,ext coolant filter,Heated W/ turn signal mirrors.Clear headlights with LED's
  #8 (permalink)
Old 05-16-2008, 10:32 PM
tr0y tr0y is offline
tr0y is starting off with a positive reputation.
Hey Fabman,
Would you share your suppliers names as you seem to have the best deals
Thanks
Troy
__________________
2003 F250 6.0PSD, 4X4, CrewCab, LWB, Airbags, B&W Gooseneck, train horn.
Soon to add 4" turbo back, Guages, and SCT with some tunes, and of course I would bet new headgaskets and studs when the truck tells me it needs them.
  #9 (permalink)
Old 05-16-2008, 10:40 PM
1935 Ford pickup
Sure.............But you're not gonna like it
I buy my supplies from Cascade Columbia Distribution in Portland Or.
I buy my Methanol in 300 gallon totes, and my KOH by the pallet. I have a wholesale account and buy in bulk. I also drive there and pick it up (137 miles away)
In order to transport it I have to have a CDL, with Hazmat endorsement.
__________________
  #10 (permalink)
Old 05-21-2008, 07:46 PM
TxFordGuy TxFordGuy is offline
TxFordGuy is starting off with a positive reputation.
What are the differences in using KOH and NOH? Any benifits from using one over the other?
__________________
2002 F-250 Lariat 4x4 CC, 4" Magnaflow SS Exhaust, Wix 6637, Petes Cover, DP-Tuner
  #11 (permalink)
Old 05-21-2008, 08:10 PM
1935 Ford pickup
Quote:
NaOH is more difficult to dissolve in Methanol, forms a very solid Glycerol, and will kill any green living thing it touches. KOH is easier to dissolve, forms a liquid glycerol, and works as a fertilizer, and can be fed to livestock.
__________________
  #12 (permalink)
Old 05-22-2008, 09:13 PM
Wookie35 Wookie35 is offline
Wookie35 is starting off with a positive reputation.
Fab, so what you are saying is depending on your intentions for your glycerol they both have potential benefits!
  #13 (permalink)
Old 05-22-2008, 09:54 PM
1935 Ford pickup
Quote:
Yes, exactly! NaOH is a great natural weed killer, but KOH is a great fertilizer.
NaOh will make a great "hard" soap, but KOH makes a great liquid soap. Both can be successfully burned to provide heat for the process, OR the shop. Both can be mixed with water and used as a dust suppressant for gravel roads, and Koh based glycerol can be pelleted and mixed with livestock feed!
I don't have a "waste-stream" Everything is reused.....................
__________________
  #14 (permalink)
Old 05-23-2008, 09:18 AM
That is my plan for my glycerol as well. I am using KOH, and the wife was very excited to hear about its use for fertilizer and composting. I may run a batch or two with NaOH just to get some "free" weed killer.
Say Fab, how about hooking me up with those methanol recovery plans? Pretty please!
  #15 (permalink)
Old 05-27-2008, 11:23 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Fab did you ever get the wood pellet idea off the ground?
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
