Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 04:58 PM
billyn is starting off with a positive reputation.
67' F100
Hi all, I have a quick question:
I recently purchased my truck and its been running great. However, when I turn it off, it kinda sputters for a few seconds before completely dying.
If any of you know how I can remedy this, I'd really appreciate it.
Thanks in advance,
Billy.
  #2 (permalink)
Old 05-12-2008, 06:23 PM
Freightrain's Avatar
Freightrain is starting off with a positive reputation.
What kind of gas are you running in it? Low grade gas will cause mine to "diesel" (run on) sometimes.
What's the timing set at and your idle speed?
__________________
1967 F100 352/4spd
1969 F100 428CJ/4 spd
and a few hot rod FORD cars too
64 Galaxie with blown 390 4 spd
64 Galaxie wagon with 428 5 spd
2006 UMTR POWERSHIFT
POINTS CHAMPION
  #3 (permalink)
Old 05-12-2008, 06:51 PM
Thanks foer the response FT,
I'm currently putting regular in, but have considered upgrading to Premium because of this very issue.
Not exactly sure of timing and exact idle speed but will be sure to check that next.
B.
  #4 (permalink)
Old 05-13-2008, 05:58 AM
jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.
Idle can be high or the timing a little too advanced is the usual culprit.
A couple work arounds until you get it fixed,
1- If auto tranny shut it off in drive.
2- If manual dump the clutch while holding the brake pedal.
Either will make enough resistance to kill the engine quickly.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #5 (permalink)
Old 05-13-2008, 11:12 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK is starting off with a positive reputation.
billyn
All the posts above make a lot of sense ,and should help. This may come from
driving lots hot rods, try patting the gas petal lightly once to clear it out, wait
for it to idle back down and shut it off! Also like already said better grade of
fuel!
Wally Womack
__________________
"Failure is an opportunity to begin again more intelligently" Henry Ford
My Pro-Street Article
  #6 (permalink)
Old 05-13-2008, 07:10 PM
blue68f100's Avatar
blue68f100 is starting off with a positive reputation.
May try de-carbon the combustion chamber with a drink of water. It's done by bring the rpm up while you pour water down the carb. Normally 12-16 oz is enough.
__________________
68 F100, mod 360, C6 Auto
  #7 (permalink)
Old 05-13-2008, 07:46 PM
I tapped the accelerator to clear it out last night, and it turned off quietly. I'm gonna upgrade the fuel as well.
Thanks to all who responded!
  #8 (permalink)
Old 05-14-2008, 10:58 AM
Roaming1 is starting off with a positive reputation.
Do you always go to the same gas station? Have problems at some and not others?
I know my 67 is picky on who's fuel I use. Even some of the top names cause mine to diesel a bit at times. I fixed my idle speed a while back and that helped a whole lot. I try to stick to one gas station which never gives me problems.
Much like people who get old our trucks can get very picky and grumpy when they have something they don't like. It would kill me to upgrade in fuel because of the cost. 10 miles per gallon is bad enough with regular unleaded prices.
  #9 (permalink)
Old 05-14-2008, 11:14 AM
I haven't gone to the same gas station consistently. Then again, I haven't had her all that long to pay close enough attention to that. I'll try and remain consistent though to see what happens.
Thanks Roaming!
  #10 (permalink)
Old 05-14-2008, 12:15 PM
An Opinion: I think brands of gas made a difference a few years ago, but I believe today that all gas is most alike with the additives that are required to be put in. I run the cheapest gas that i can find and really don't see any differences.
My 2 cents will be on timing or idle first before brand of gas, causing dieseling. That was the issue that caused my van to diesel a few years back.
John
__________________
  #11 (permalink)
Old 05-15-2008, 07:31 AM
I bought gas at a Shell station about a month ago and had a slight dieseling problem. I also use the cheapest gas station in town and never have a problem. Perhaps my motor is extra picky but mine just doesn't like certain tanks of gas.
  #12 (permalink)
Old 05-15-2008, 08:21 AM
billyn
Keep in mind the gas stations should be changing from (winter) blend= crap,
back to (summer) blend= little better gas! At least that is what they claim!
Wally Womack
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
