Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 04:56 PM
hillbillyk is starting off with a positive reputation.
77 f-100 wiring issues
I am working on a 77 f-100, swapped the body on a 4x4 frame. I cannot get any power to the fuse box except for the lights. Also no power to the ignition switch except for one wire that does not seem to do anything. This problem is driving me nuts, I cannot find a wiring diagram with all the parts on it to go off of. My chilton and haynes manual does not have the right diagram, and the shop manual does not have a complete wiring diagram. Does anyone know where I can get one, or have a clue for this problem. It's a 77 f100 ranger with a/c. Thanks for any help.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-12-2008, 04:59 PM
sparky's Avatar
sparky is starting off with a positive reputation.
Just a thought but did you hook the fusible links on the starter relay to the same post as the battery positive?
__________________
Sparky
  #3 (permalink)
Old 05-12-2008, 05:11 PM
that was the first thing I checked, I have all 3 of them on there and even cleaned them up nice, then checked the voltage before and after the fusible links to make sure they were ok. I wonder if the power might go to the fuse box throught the air conditioning harness, this wiring is a pain in the butt.
  #4 (permalink)
Old 05-12-2008, 05:22 PM
sparky's Avatar
I am sure the fusible links feed the fuse box and the ignition switch...........if you have voltage on each side of the link try a few feet up the wire.....maybe the links are blown and you are measuring before the "open" part of the link.
Maybe ensure the grounds for the cab, engine, etc are good... could be the voltage is available but there is no ground????? Just a guess though.
Are you positive that all the connectors are hooked up......been a while since I worked on those "new" 70's trucks
__________________
Sparky
  #5 (permalink)
Old 05-12-2008, 05:35 PM
I traced the wires, one of the fused wires ends up at an a/c connection, and the other goes to the lights, which work. It's tough to figure it out without an accurate wiring diagram. All the grounds are good, checked them out. When I bought the parts truck you had to start it from the starter realay so I'm not sure what the problem would be.
  #6 (permalink)
Old 05-12-2008, 05:45 PM
sparky's Avatar
This may help some, generic wiring diagram so it should be some what accurate....
AutoZone.com | Vehicle Selection - Year
__________________
Sparky
  #7 (permalink)
Old 05-12-2008, 05:52 PM
sparky's Avatar
Another thought....... try another ignition switch if you have one... you said there was power to one wire so....... it may be the power feed to the ignition switch that feeds the fuse box when the key is on......but if the switch is dead...... no path for power
__________________
Sparky
  #8 (permalink)
Old 05-12-2008, 08:08 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
This diagram shows a black/yellow going to the ignition switch. There is usually a splice along the way where it splits and also feeds the fuse box. If you can't find the black yellow at the starter solenoid, then start at the ignition switch and look for a black/yellow and work your way back.
http://www.autozone.com/images/cds/g...3d800ce986.gif
__________________
Dave F
1989 F250 XLT Diesel
  #9 (permalink)
Old 05-12-2008, 08:41 PM
that is the same diagram I have been using, and alot of the colors don't match, and alot of the parts don't match, and the a/c option seems to change alot of things. All of the larger wires that you would think feed the fuse panel run to the a/c parts, they seem to turn into a bunch of small wires, then back into the large ones that run into the fuse panel. I think the black yellow wire ended up going to the a/c, I have power to the interior and exterior light part of the fuse panel and that's it. I think I just need the correct 77 diagram, that one on the autozone site is the same in the chiltons and haynes manual, and it lists for 73-78, I know there were changes in there, it's to generic.
  #10 (permalink)
Old 05-13-2008, 08:54 AM
sparky's Avatar
Couple more thoughts
You say the large wires go to the ac plug and then turn into small wires and back to large wires....... so any chance those small wires are fusible links????
If you have power to the "always hot" parts of the fuse box, lights, then it appears you are missing the switched circuits....... so these are controlled by the key/ignition switch............. so a large wire to the switch should have 12 volts on it that is "switched" to feed the other large wires that feed the fuse box in "acc" and "run"..................... so if that voltage is missing I guess you have to start tracing wires................. no fun in these trucks.....especially if there has been some well intentioned wire mods done by PO's
__________________
Sparky
  #11 (permalink)
Old 05-13-2008, 04:38 PM
Franklin2's Avatar
Here's a wiring diagram and the price is not too bad.
1977 FORD F SERIES F100 THRU F350 TRUCK WIRING DIAGRAM - eBay (item 180231314159 end time Jun-06-08 15:08:50 PDT)
__________________
Dave F
  #12 (permalink)
Old 05-13-2008, 10:21 PM
Thanks for that link, I was looking for one of those. So the fuse panel, other then the lights, is wired through the ignition switch? I was thinking that, Now I just need to know where the wires are supposed to come from. I think I have found all the fusable links, but I think ford liked to hide a few that are hard to find in the dash wiring. I will do more checking this weekend, and hopefully I'll have my diagram soon. The harness looks other then a radio un mollested, kinda suprising for a 77, but It was a gov. truck for a long time so it probally sat most of it's life. Thanks for the help, I'll report back when I find something, and keep the ideas coming, they are a big help.
  #13 (permalink)
Old 05-14-2008, 04:34 PM
Franklin2's Avatar
Some of the fuse box is fed by the ignition switch. The stuff that only works with the key on like the radio, the heater blower, the turnsignals, etc. The rest of the fuse box is fed by the same wire that feeds the ignition switch. This is for stuff that works all the time, like the brake lights, dome lights, marker lights, etc. The headlights have their own seperate feed directly from the starter solenoid.
__________________
Dave F
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
