Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 03:20 PM
Dholt is starting off with a positive reputation.
Unhappy 1996 power stroke power problem
I have a 1996 7.3 power stroke and I am pulling about 15000 lbs on a goose neck. When pulling up hills I seem to run out of power but on the straight it pulls great. It just seems to be running out of power running up hill. I have talked to other people about pulling up grades and for them there is no issue, they seem to be able to pull up hill at a speed arround 55 mph I tend to drop to about 30 on the same hill. The fuel filter has been changed and the oil is fresh and full. I have heard of an issue with the fuel heater that might cause this issue. I do have a new one but have not istallted it as of yet. Any ideas I could check, chould it also be an injector issue?????
  #2 (permalink)
Old 05-12-2008, 06:57 PM
ReAX's Avatar
ReAX is gaining momentum as a positive member of FTE.
Do they have the same gear ratio? Pulling 15k lbs uphill is a lot of work, gearing could do a lot of help or harm to your cause.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #3 (permalink)
Old 05-13-2008, 11:14 AM
The gearing on the truck seems to be fine. I just seem to lose power when climbing hills, like I am running out of gas.
  #4 (permalink)
Old 05-13-2008, 11:33 AM
sealer700 is starting off with a positive reputation.
An aquaintence of mine had same problem and her tranny was going out.
__________________
2006 F-250 Crew 6.0 All stock with Boss 9'2 v plow
1999 F-250 x-cab V-10 Lifted,Boss plow, Ez dump
1993 F-250 Regular Cab "gettin tired" 5.8
  #5 (permalink)
Old 05-13-2008, 12:20 PM
Trany is fresh. With all the upgrades to it as well.
  #6 (permalink)
Old 05-13-2008, 04:52 PM
ryaneverk2's Avatar
ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.
Thread moved to the 7.3L PSD section.
__________________
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator/tee, ATS housing, BBHA, CCV Mod, SS HPX, DP-Tuner, BTS-VB, lots of LEDs, and more...
My Truck Pics
7.3L Common Mods/Maint. and Hard Starting
Super Duty Tech Folder and FAQ
  #7 (permalink)
Old 05-13-2008, 04:58 PM
immastrokinnow's Avatar
immastrokinnow is starting off with a positive reputation.
what gear ratio do you have? like reAX said 15k is alot of weight on a steep grade. how does you air filter look and is the truck stock?
__________________
1997 psd x-cab long bed 4x4
tymar intake
3in dp FINALLY IN
bullydog 4 bank 6 pos. chip (crap)
6in bull haulers
missing cat and muffler
blown trans
fpr shim
soon to be
NEW TRANS
gauges (egt, boost, trans temp)
dp tuner (ditch the bully dog)
intercooler
stage 2 diy- injectors
superduty hpop
Dom. d66
dan
  #8 (permalink)
Old 05-13-2008, 05:11 PM
Hussler's Avatar
Hussler is starting off with a positive reputation.
Check your Map sensor hose for any pin-holes and possible clogs. Just take it off and blow in one end of it to ensure it is clear, not plugged up. Bad Map sensor hose = poor power. If it is rock hard where it connects to the engine just replace it. Cheep fix if that's the problem.
__________________
1997 F250 HD CC 4x4
7.3L - E4OD - 3.55's
EVBP Disconnected
Napa 6637 - FPR Shim
New - MAP Sensor Hose
The only thing I pull is the extension cord to my truck.
  #9 (permalink)
Old 05-13-2008, 08:23 PM
tjbeggs's Avatar
Fisher of Men
tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.
Another check for the MAP is to unplug the electrical connector and if the truck has better performance you either have a plugged/leaking line or a bad sensor.
Also check fuel pressure at idle and under load. you should not drop below 40-50 psi. It will be hard measure do to the mechanical pump giving lots of pulsations.
__________________
Tim
Proud User of "The Cure"
For sale- 95 accelerator pedal, Gray interior and dash part, cab and more PM your request!
Click the Picture for wiring diagrams, tech info and Pictures!
  #10 (permalink)
Old 05-13-2008, 08:58 PM
c00nhunterjoe's Avatar
c00nhunterjoe has a good reputation on FTE.c00nhunterjoe has a good reputation on FTE.
what is done to your truck other than tranny mods? what size tires? chip? intake? exhaust? gears? how steep are these hills?
__________________
97 F-250, 4.10's Auto, Superchip, All mods by c00nhunterjoe's performance shop http://community.webshots.com/user/c00nhunterjoe
http://youtube.com/c00nhunterjoe
  #11 (permalink)
Old 05-14-2008, 08:03 AM
Neal 97 250's Avatar
Neal 97 250 is gaining momentum as a positive member of FTE.Neal 97 250 is gaining momentum as a positive member of FTE.
Clean the screen in the filter bowl also.
__________________
97 F250 7.3PSD
X-Cab, SWB, 4X4
5spd, 4.10gears
3.5” DP, 4” Exh.
AFE Intake
FPR,BDP 140v IDM,CCV,HPX
Rosewood Stage II's
6 pos. TW chip, wow !!
'00 Excursion 7.3PSD 4X4
6637 intake
drill/slot rotors
Neal's Pics
  #12 (permalink)
Old 05-14-2008, 01:20 PM
I do have mods on my truck. I have the upgraded exhaust system, a K&N filter and a chip mod. The chip mod I can change from tow to extream. I do have all the guages to monitor the engine while in these mod configuations. I have heard of oil foaming which might cause this problem but Im not sure of that as well. I use synthethic oil, but I have not changed it in about 15k miles, I do keep it full though. My truck is not modified with any tires or such, but it is a 4x4 with standard 4x4 tires no mud running for me. Like I said the trans has been gone through with all the mods it can take. I have a triple clutch converter and there was another cluch plate added to the tranny. The air filter is clean so no stopage there. I do try to run fuel additive in the tank just because of the crap in the fuel now days. I think that is about all of it that I can think of. Thanks for all your great responces. I will just have to find the map sensor to check that one out, any ideas where that is located?
  #13 (permalink)
Old 05-14-2008, 01:32 PM
tjbeggs's Avatar
Fisher of Men
MAP sensor (follow the small black hose from the regulator (center of pic, small round gauge with bad reflection on it) to the gray box to the left hand side of the pictures. Thats the MAP sensor
Your K+N isn't by chance a drop in into the stock box is it? I hope not. If so, remove the intake tubing and make sure you compressor wheel on the turbo doesn't look sand blast or nicked. it should have straight edges nice and clean with 90 corners of the outside edge.
__________________
Tim
  #14 (permalink)
Old 05-14-2008, 01:59 PM
Pest007's Avatar
Pest007 is starting off with a positive reputation.
Do you tow with OD or is the truck shift down, what gear and RPM is it in when pulling 55, and then 30 on the hills?
__________________
1996 F250 PSD Ex-cab 4x4
Dana 50 front axle with Warn locking hubs
Tuff Country 2.5" lift
Autometer Gauges
Banks Stinger-plus system w/Ram Air intake w/K&N
Banks Trans-command Module
7.3 SD intercooler mod
MAP sensor mod
JVC mp3 player with boom-tube system
  #15 (permalink)
Old 05-14-2008, 02:09 PM
Thanks for the pic on the Map sensor.
When I pull hills I drop of the OD which helps on the hills but then when pulling biger hills and the speed drops to arround 40 or lower the rpms seem to be high and the trans seems to drop down to 2ed. I have a small hill comming up to my house and I start up the hill at a rolling start and I can only get up to about 20 mph and I blow a lot of smoke. It seems the truck will go to 2ed gear and stay there at about 20 mph. This is very frustrating and I know that this truck will pull better than that. The trailer I am pulling tops out arround 20k when loaded with 4 horses and full tack. The trailer is 42.5 ft and has a living area with it. Pulling on the flat it pulls really great and gets up to speed quickly, its just pulling hills.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
