serp. belt
Old 05-13-2008, 07:09 AM
Todd K's Avatar
Todd K
Todd K is offline
serp. belt
my serp. belt has been squeeking for a while now. any one else have this problem and what can i do to fix it? thanks
Old 05-13-2008, 08:36 AM
mattd17's Avatar
mattd17
mattd17 is offline
you could try a belt dressing, which would only be temporary...... best option would be to replace it.... what year is your ride? how much mileage? are you sure its the belt itself, and not a pulley on the idler, or alternator?
Old 05-13-2008, 10:27 AM
FatalErrorz's Avatar
FatalErrorz
FatalErrorz is offline
I read on here about some guy who cleaned his splines with a wet paintbrush while the engine was running and that took care of the noise. He'd changed belts, pulleys, tensioners, alternator,etc. It turned out to be the auto car wash blowing crap onto his belt which made it squeak. But if you have 5 trillion miles on it, then you should probably change your belt.
Old 05-13-2008, 10:53 AM
Twinsdad98's Avatar
Twinsdad98
Twinsdad98 is offline
I agree with Matt- it could be lots of things, but without knowing mileage etc.. Ford has had issues with tensioners in the past, but as Fatal says, the belt could be dirty as well. If you have 90K on it, I'd probably change the belt. Goodyear Gatorback is a great belt.
Old 05-13-2008, 02:14 PM
NASSTY's Avatar
NASSTY
NASSTY is offline
+1
Get a Goodyear Gatorback belt.
