Merc Maurader 4.6 to F-150?
Old 05-13-2008, 01:29 PM
thewheelman's Avatar
thewheelman
thewheelman is offline
So, I'm always thinking about how to get more out of the 4.6 in my F-150 screw. What's the difference in the 300 horse Maurader engine and our 4.6's? Throttle body? Programming? Injectors? Intake? Are there any internal differences? In other words, could I bolt on the Maurader parts and up the horsepower on my truck?
Thanks!
Old 05-13-2008, 02:53 PM
86halfton's Avatar
86halfton
86halfton is offline
the maurader engine is a DOHC engine 4 cams, 32 valves
the intake on the maurader is better, im sure the maurader has more compression
our engines, sohc , 2 cams, 16 valves
Old 05-13-2008, 03:06 PM
thewheelman
Cool, so the maurader engine is the same as the Mustang, not the F-150.....I'm begining to understand.....
Old 05-13-2008, 03:14 PM
86halfton's Avatar
86halfton
similar , the mustang GT engine is also known as a 2V engine, which is same as our trucks, execpt the newer GT which are 3V (which means 3 valves per cylinder) variable cam timing
