Another thing that could have happened is that a pin hole leak could have opend up on the short piece of rubber fuel hose that runs from the pump to the metal line inside the tank. This small leak isn't enough to make the pump keep running to build up pressure when the key is first turned on. But it will make it not supply enough pressure for starting when you actually crank it over. So you have to keep cranking till it starts. This is what was going on with my 91 Ranger recently. When I got the pump & sender unit out of the tank I didn't see the bad spot in the small hose at first. But after it dried off on the out side of the hose, one place kept getting wet again and that's where the pin hole was. There are two other possibilities. One is the fuel pressure regulator isn't working right or the pump just isn't making the pressure it should. But from what I've seen in the past, that little fuel hose will go bad way before the pump or regulator does.
__________________
1991 Ranger XLT SC 4.0 A4LD 2wd 180,000 plus
1990 Ranger XLT SC 2.9 5spd 2wd 229,000 plus
