Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 02:34 PM
BRONCOBITCH94 is starting off with a positive reputation.
Question 94 bronco brake problem..no pedal..
pulled into work last week hit the brakes hard and broke a caliper....(yea its possible) i replaced the drivers side caliper and changed pads.. gravity bled the brakes... and no pedal...replaced the passenger side caliper, gravity bled again... no pedal... replaced the master cylinder, gravity bled... no pedal... replaced the brake booster gravity bled...and in case u havent guess it i still have no pedal...does anybody have any clue what else could be wrong?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-12-2008, 03:31 PM
alxsnmr is starting off with a positive reputation.
The first thing is your bleeding procedure, furthest brake from the master then work progressively closer to the master cylinder. If the brake pedel is still soft or nothing then your master may be loosing pressure back to the resiovoir, i.e. replace the master cylinder.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, otherwise still stock.
  #3 (permalink)
Old 05-12-2008, 03:44 PM
bossind's Avatar
bossind is starting off with a positive reputation.
Quote:
Ok lets see, brake booster has nothing to do with this, so you replaced that needlessly, anyways heres what you need to do......BLEED the brakes and bleed it lots, you have opened the system a number of times and likely have air behind the fluid your seeing as clear. Put at least two jugs through it and start at the rear passenger side wheel, bleed lots here.
__________________
-Steve
96 Bronco, SAS, 4.88, 35s, Hydro Boost, 3" exhaust, 4 wheel Disc brakes, Sag PS Pump.
  #4 (permalink)
Old 05-13-2008, 02:12 PM
bking33 is starting off with a positive reputation.
Do you have ABS?If you do your HCU is probly bad.I have run into this before.I would Make sure that you have bled properly not just gravity bled.If you still have no pedal than it has to be HCU(if you have ABS.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
