Quote:
Originally Posted by BRONCOBITCH94
pulled into work last week hit the brakes hard and broke a caliper....(yea its possible) i replaced the drivers side caliper and changed pads.. gravity bled the brakes... and no pedal...replaced the passenger side caliper, gravity bled again... no pedal... replaced the master cylinder, gravity bled... no pedal... replaced the brake booster gravity bled...and in case u havent guess it i still have no pedal...does anybody have any clue what else could be wrong?
Ok lets see, brake booster has nothing to do with this, so you replaced that needlessly, anyways heres what you need to do......BLEED the brakes and bleed it lots, you have opened the system a number of times and likely have air behind the fluid your seeing as clear. Put at least two jugs through it and start at the rear passenger side wheel, bleed lots here.
