Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 6.4L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 01:47 PM
Bluemountain is starting off with a positive reputation.
Turbo scream
I have a 10,000# camper that I tow regulary. When going up a hill or under heavy acceleration and at full boost it sounds like the turbo is going to blow apart! It gets a high pitch scream, not like a typical turbo whine but like bearings grinding together with no grease. As soon is let off the gas and the boost drops just a hair it goes away. My truck is a 08 job#1 350 SW. Has anyone noticed this? Just added BANKS DPF back exhaust scared to do DPF delete at this point. Ordered Job #2 air damn see if that helps MPG.
Love the truck. I had a 2003 6.0 blew up turbo first time towing camper with three young kids and mad wife, had to get rid of it!
  #2 (permalink)
Old 05-12-2008, 10:06 PM
SANDDEMON08's Avatar
FORD POWERSTROKE JUNKY
SANDDEMON08 is gaining momentum as a positive member of FTE.SANDDEMON08 is gaining momentum as a positive member of FTE.
Welcome to
Do you have any other mods on the truck? Does it only do it when your towing? Describe the scream a little more.
__________________
Got beer ? 434HP 765 TQ
2008 F350 SD CC FX4 ON 20's, 6.4 PSD,TORQ-SHIFT,3.73 REARS, NAV, BLACK LEATHER SEATS,DASH DAQ GAUGES, AFE STAGE II INTAKE,CUSTOM TUNING, SEIC IDLE MOD,AMP REASEARCH STEPS, LINE-X SPRAY IN BED LINER, T-REX BILLET SIDE VENTS.
  #3 (permalink)
Old 05-13-2008, 08:55 AM
Chauncey's Avatar
Chauncey is gaining momentum as a positive member of FTE.
Where is the boost gage needle when this happens?
__________________
"GREENIES" BEWARE-My goal is to use my full share of the available fossil fuels plus any shares left unclaimed!
06 F-150 Lariat SCREW
08 6.4 SD 250 King Ranch crew 4X4
05 Cadillac SRX
  #4 (permalink)
Old 05-13-2008, 11:10 AM
No other mods, just DPF back Banks dual exhaust (it made that noise before exhaust). Just when towing heavy load with RPM'S fairly high, boost gauge is around 32# pounds or so. The sound is like when a bearing is going bad, its not just one tone but a grinding multiple high pitch whine.
I feel that that commercial :"my car goes clunk can you help"
Thanks for any info you may have.
  #5 (permalink)
Old 05-13-2008, 02:17 PM
chopper chik is starting off with a positive reputation.
bad bearing/bushing in the turbo.
  #6 (permalink)
Old 05-13-2008, 03:10 PM
Why would it only happen under heavy load? Without pulling trailer and mashing the gas no noise.
  #7 (permalink)
Old 05-13-2008, 03:41 PM
mikey2000 is starting off with a positive reputation.
I bet it is the fan kicking in under load.
__________________
2008 Dark Shadow Gray F450 Pick Up w/4.88
  #8 (permalink)
Old 05-13-2008, 03:47 PM
Noise comes directly from behind firewall.
  #9 (permalink)
Old 05-13-2008, 05:51 PM
fruth04 is starting off with a positive reputation.
hey its got a the 100k warranty drive it and see what happens might get worse.... might get better.... likely worse..... but i would wait and see OR have it looked at and if they say it needs a turbo, drive it till they get one in..... i would hook on the camper and have a mechanic hop in...
__________________
2003 F-150.... Airaid, edge evo, piaa's, exhaust and just about all the chrome u can buy...
  #10 (permalink)
Old 05-14-2008, 03:12 AM
iridesand06 is starting off with a positive reputation.
Check all 4 of the charge air cooler connections at the intercooler and intake manifold. If you see oil leaking from any of these connections thats a sign of air leak from the boot. This is why you only hear the sound under full boost situations like towing.
  #11 (permalink)
Old 05-14-2008, 08:39 AM
Demolition is starting off with a positive reputation.
Blue, not sure if you are aware of the heater core whine that some Job 1 trucks experience under acceleration. I had this on my 350 and it sounds like a turbo problem. The sound seems to come from directly behind the firewall as you noted as well. The sound is actually the coolant/water rushing through the hose behind the center stack.
This may be the issue if it turns out that your turbo is ok.
__________________
08 F250 KR PSD CC 4X4 Auto 3.73 SWB Line-X FS2500 Bypass Oil Filter, Viper 791XV w/remote start. Insight Multi Gauge Display. Retrax.
08 F350 KR PSD CC 4X4 SRW Auto 3.73 (Sold)
  #12 (permalink)
Old 05-14-2008, 04:19 PM
Will check! Thanks for the info
  #13 (permalink)
Old 06-03-2008, 11:23 PM
aglenn's Avatar
aglenn is starting off with a positive reputation.
My 08 F-450 had a loud turbo noise at high boost. I happened to have a camcorder and played it at he dealer when I took it in. He had to investigate a few days to get to the root cause. I recall it was something to do with a fuel cooler pump that had to be purged, the noise was caused by air in the system. Anyway the turbo was OK and the noise is gone.
  #14 (permalink)
Old 06-04-2008, 09:04 AM
B-52 is starting off with a positive reputation.
Same noise on my truck and it was that heater core. Sounds nasty and only at high RPM with a big load on. I would have them check that 1st.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
