timing chain broke - Ford Truck Enthusiasts Forums
timing chain broke
Old 05-12-2008, 02:47 PM
grizzqc grizzqc is offline
grizzqc is starting off with a positive reputation.
timing chain broke
f150 4.9 1988 timing chain let go garage just called bummer.What kind of damage should i expect ?only 146,000km still new?
Old 05-12-2008, 04:39 PM
Virto's Avatar
Virto Virto is offline
Virto has a good reputation on FTE.Virto has a good reputation on FTE.Virto has a good reputation on FTE.
These are non interference engines, so shouldn't be too bad unless the broken chain took out the cover or caused any external damage.
EDIT: Oops, you've got a big 6. The 6 doesn't have a timing chain, it has timing gears, IIRC. More work to replace.
Old 05-12-2008, 07:24 PM
ok thx miss understood garage.Is it still non interference motor?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
