Towing Capacity? 2001 F-150 4.6 V-8
Old 05-12-2008, 01:26 PM
bigbadben's Avatar
bigbadben
bigbadben is offline
I have a 2001 F-150 4.6 V-8
How can I find the towing capacity? My owners manual is packed away somewhere and Im killing myself to find it.
Im buying a travel trailer to pull on a frame mounted receiver hitch (not a 5th wheel), and just want to make sure I can tow it!
Old 05-12-2008, 02:12 PM
92merc's Avatar
92merc
92merc is offline
Depends on your gear ratio and whether you're 4x4, and what cab and tires.
Here are some of the more common configurations:
Extended 4x2
3.31 gear 5900 lbs trailer 10,500 GVW
3.55 6900 11,500
Extended 4x4
16 inch tires 3.55 6600
17 in tires 3.55 6100
Old 05-13-2008, 08:49 AM
bigbadben's Avatar
bigbadben
Cool, Thanks!
Mine is an extended cab, flare side. It is not 4X4.
Looks like Im well within towing range if 10,500 is the max.
Old 05-13-2008, 09:08 AM
92merc's Avatar
92merc
92merc is offline
10,500 is the max gross vehicle weight. Meaning weight of your truck, plus trailer and load.
Old 05-13-2008, 10:59 AM
bigbadben's Avatar
bigbadben
cool
thanks
Old 05-14-2008, 10:38 AM
bigbadben's Avatar
bigbadben
I appreciate the info!
The RV I will be hauling is well within range. Just got to make sure I dont overload it! ha
Old 05-15-2008, 01:30 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
You need to be concerned about the Gross combined weight rating for the truck model and how it is equipped.
Then subtract passengers and any other weight from the trailer 'Loaded' weight.
There is more to this than just looking at one source of trailer weight and saying that's all there is to it.
Then there is transmission cooling and radiator cooling capacity for long haul .
Believe it, there is more to this than just simply knowing trailer weight.
You need an electric brake controller as well.
jdaugela
1997 - 2003 F150
11-20-2022 04:40 PM
mjcb2000
1997 - 2003 F150
04-24-2020 06:54 AM
awonboys
2004 - 2008 F150
12-29-2013 09:52 PM
panelguy
1997 - 2003 F150
08-26-2013 04:10 PM
GOS9S
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
08-25-2005 06:17 AM
Quick Reply: Towing Capacity? 2001 F-150 4.6 V-8
