Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 01:18 PM
camper1083 is starting off with a positive reputation.
Pulling AWD Fuse 03 Explorer
I was reading one of the threads about pulling the AWD fuse on a 02 explorer and was wondering if I could do the same on my 03 explorer v8? I looked in my owners manual and there was a PTEC fuse and a PCM fuse as well as some 4x4 fuses. If this does work, which one do I pull to disengage the awd? I have been having some trouble with my awd. as long as I am going straight I am fine, but if I turn even slightly it engages the front wheels. Highly annoying! Help!
  #2 (permalink)
Old 05-12-2008, 04:50 PM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Well, my first question is why would you want to. The AWD system has all 4 wheels engaged simultaneously. It remains engaged all the time whether the system is powered or not. The AWD computer uses a speed sensor on the front and rear axle that allows the computer to look for a speed difference. If a difference of more than a certain amount is found, the AWD system will activate a clutch that locks the front and rear axles together. If the system is engaging when it is not supposed to, it most likely means that one or both speed sensors is faulty. The best solution is to fix the problem by replacing the faulty component. Removing the fuse will prevent the system from going into lockup, but is really intended as a temporary solution.
To answer your question, if you pull the fuse, the AWD computer will be disabled, though you may get a code and a light on the dash. Unplugging the AWD computer will do the same thing except you shouldn't have a code.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #3 (permalink)
Old 05-12-2008, 05:32 PM
Good point about it being a temporary fix.
Is the sensor an easy fix or does this require a some work?
  #4 (permalink)
Old 05-12-2008, 07:30 PM
beater79's Avatar
beater79 is starting off with a positive reputation.
Quote:
You may want to check your tires. If the front are lower PSI than the rear it would cause the AWD module to think that one tire was slipping because it is turning slower/faster than the others. You will also want to make sure that all 4 wheels tread depth is within 3-5/32 of each other. The circumference of them could cause the same concern. Does the AWD light flash at any time? I am a Ford tech of 5 years and a heavy duty truck and bus technician. I have seen some customers AWD Explorers with teh same issue and checked the tires as I described and found that the tires were causing the concern. Changed tires andthe concern went away. Hope this info helps and good luck!
  #5 (permalink)
Old 05-12-2008, 07:40 PM
Thanks for the reply. I wish it was just the tires, but I had this problem with two different sets of tires. I really just want someone to tell me which fuse to pull. I have read through multiple threads and everyone says pull the "auto clutch fuse". That fuse may exist, but it is not called that in my explorer handbook. I am not a professional mechanic so please excuse me for not knowing what fuse does what. Thanks for the help and suggestions!
  #6 (permalink)
Old 05-12-2008, 07:45 PM
beater79's Avatar
hey camper1083, send me a pm with all info about your truck and I will check at work tomorrow. We have a Ford dealer only site we use to talk with the engineers and to pull up schematics you wont find in any "aftermarket manual", I will check it out for ya and pm ya back tomorrow night.
  #7 (permalink)
Old 05-13-2008, 07:17 PM
beater79's Avatar
camper1083, I tried to send you a pm tonight but it says you are not accepting pms. pm me if you can with your email so I can give you the info I found for your truck. Thanks.
__________________
79 F-150 short bed, 400m, 4spd, 4x4, 4" rancho lift
96 explorer 4.0 auto, k&n filter, stock
  #8 (permalink)
Old 05-14-2008, 06:01 AM
I can't get private messages anymore so can you just post the answer as a reply?
  #9 (permalink)
Old 05-16-2008, 02:48 PM
paul1910 is starting off with a positive reputation.
beater the door sticker states front and rear tire pressure be 5psi diff between front and rear...........should all tires be same pressure i am having a problem with my o/d light flashing got a code for a stuck off tcc soleniod put the problem showed up after i rotated the tires and corrected the pressure also get an intermintent abs light to come on and i already changed out the rear diff sensor that light came on after the tires rotated and psi adjusted what tires should i be running and at what psi so all the sensors work properlly
  #10 (permalink)
Old 05-16-2008, 05:43 PM
beater79's Avatar
Quote:
No, the code you have for the tcc valve has nothing to do with your tires. You are experiencing the Explorer trans problem. Mine did the same thing. You have to pull your pan off and find the valve, depending on what model you have, it will be towards the front of the valve body or I believe on the side, I think the pass side of the valve body.
__________________
  #11 (permalink)
Old 05-16-2008, 05:48 PM
beater79's Avatar
Sorry took so long to reply back to ya.
What I found is a TSB for the auto transfer case system. It is thinking your front wheels are slipping therefore locking in. If I remember right, it said it is due to a wiring short or shorted wheel speed sensor. As for pulling the fuse, I was told that it would mess up the transmission shift points because it reads off of the input from your wheel speed sensors through the PCM as does the transfercase. I hope this helps you out it fixing it!
__________________
  #12 (permalink)
Old 05-16-2008, 08:11 PM
i have an 03 awd mountaineer so is the tcc right there when i take the pan and filter off according to all-data thats what it looks like in the diagram so if i remove and replace the tcc soleniod it should be good..........im having a mechanic do the diagnostic on thurs to find out exactly what it is it still runs fine shifts fine od seems to go on and off when i hit the switch by the rpms going up and down
  #13 (permalink)
Old 05-16-2008, 09:25 PM
beater79's Avatar
it just means that it is sticking every now and then, the seals in it might be getting worn. I think that if you replace it that it would be fixed.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
