Brake Controller relay/fuse - Ford Truck Enthusiasts Forums
Old 05-12-2008, 12:19 PM
92merc 92merc is offline
92merc is starting off with a positive reputation.
I'm trying to help out my dad with his 2001 Screw F150 and brake controller wiring. I have a 2003 Screw, so I can look at mine to compare.
His came with the tow package, but I suspect they didn't include the relay/fuse/pigtail with it. He bought the truck used and it has 100k miles on it. So I'm sure that kit is long gone.
He bought the pigtail and wired in the controller to the connector under the dash, but the controller doesn't have the hot feed going to it. I suspect it's missing the fuse and relays that are supposed to go under the hood. Can anyone tell me what fuse position is needed and what relays are needed?
Old 05-13-2008, 02:26 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
In the battery junction box (BJB) under the hood, there are three relays associated with the trailer wiring. K355, K356, and K357.
  • K355 Battery Charge Relay (Full relay)
  • K356 Parking Lamp Relay (Half relay)
  • K357 Reversing Lamp Relay(Half relay)
Fuses are in the BJB too.
  • F101 30A
  • F108 30A
  • F5 20A
Good luck!
Old 05-13-2008, 02:45 PM
Thanks. I dug out my PDF of the owner's manual and took it to my truck. On my truck, I have all of those except the full relay and the reverse half relay. So I'll be calling my dad tonight to see what he has. I'm also thinking he may have a blown that 108 fuse. That might explain why he has no power to the brake controller.
BTW, my manual and truck show:
302: Trailer tow battery charge relay (Full relay)
201: Trailer tow park lamp relay (Half Relay)
203: Trailer tow backup lamp relay (Half Relay)
Your numbers might be from the newer 2004+.
Old 05-13-2008, 03:49 PM
Nope, out of my 2002 Ford F-150 Wiring Diagram manual.
Old 05-15-2008, 10:01 AM
After talking to my dad, I found out something else odd. My truck came with the factory tow package. His didn't. He was able to find the wires under the truck at the rear to mount everything up for a 7 pin plug. Even the tap for the electric controller is there. But when you look at the fuses, Fuse 101 was not only empty, there was no blade for the maxi fuse to connect to. One blade was there, the other wasn't.
I figured out how to pop my fuse box up and turn it over. I was able to see the bottom side of fuse 101 and see that there is a dark green solid wire to mine. I let my dad know. I'm hoping that wire is there in with all the other wires and he just needs to plug it in at the bottom.
No brake lights, turn signals or flashers?? TSmylie Excursion - King of SUVs 11 09-14-2014 04:45 PM
Reverse lights stay on after installing the Trailer relays, Help! Two000F250 1997 - 2003 F150 1 09-07-2013 04:04 PM
Blowing trailer lights fuse. Billyclub Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 10 05-18-2010 01:11 AM
Brake Controller Fuse and Relay Question kailor 1997-2006 Expedition & Navigator 5 08-11-2008 05:27 PM
Electric brake controller: Relay under hood??? nmlaz 1999 to 2016 Super Duty 12 03-05-2007 10:18 AM
Tags
2003, brake, dark, f150, f250, fuse, green, lamp, location, package, relay, reverse, sable, towing, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
