Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 05-13-2008, 12:21 AM
tex25025's Avatar
tex25025 has a good reputation on FTE.tex25025 has a good reputation on FTE.
Quote:
Originally Posted by nitrogen View Post
just to get it clear who is making the FICM tunes? are they part of the SCT unit or is it separate? what is the name of Matt's outfit? thanks
Right now I'm one of the few that are beta testing the FICM tuning for Matt's new tuner. His company is Spartan Diesel Technologies. SCT is doing their own research into that I believe, so it will be with their stuff. Matt was able to use his FICM with my xCal 2, but that will change when his new stuff is ready to go.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 05-13-2008, 01:37 AM
doubledee715's Avatar
doubledee715 is starting off with a positive reputation.
Quote:
Originally Posted by scarm View Post
Anyway - It would be good to hear more why SCT over the banks - the only reason I'm leaning toward the banks is because you can get all kinds of readings with the palm tungsten hookup
those readings don't make it worth it. Please don't be one of the statistics that falls for the Banks advertising. I'm one of many that have gone from edge to custom tunes. If you're gonna add power, imo, do it the right way.
__________________
David, 2003 f250 6.0 cc sb Centennial Edition, Dieselsite coolant filter, afe stage 2 w/pg7, ejf1000 edge juice w/attitude replaced w/innovative tuned xcal, blocked off egr cooler, Quadzilla Commander w/pillar mount, ARP studs, ITP RR, 05 accufab elbow, 4" tb, pic
  #18 (permalink)
Old 05-13-2008, 05:15 AM
scarm is starting off with a positive reputation.
Why is everybody so down on the banks stuff - from what I have read - the six gun with the Palm Tungsten hookup gives you all kinds of information and adjustment capabilities. I like the Idea of the SCT with a Matt progam (it's one helluva lot cheaper) but I also like the ability to monitor what is going on with my truck from one unit. I really don't want to install a bunch of gages.
  #19 (permalink)
Old 05-13-2008, 05:30 AM
because you're adding power to your motor and leaving your tranny to fend for itself. custom tunes adjust ecm and tcm so they work together.
__________________
  #20 (permalink)
Old 05-13-2008, 07:07 AM
tex25025's Avatar
Here is a copy of a post that I made in another thread, but still applies to this one. Now while the post focuses on the bullydog monitor in particular it is not limited to that it also applies to the pda that your talking about as well.
Two problems that I have had with digital monitors that use the OBD-II connection.
1. They rely on the Ford gauges and I have noticed(particularly with the tranny) that some of those gauges give off a cooler reading then what I get with the analog gauges. Which isn't a good thing, because their are parts of what you are monitoring that are hotter then what you are reading so therefore, you run the risk of burning something up despite the fact that your monitoring the gauges. Now you can compensate for that if you know the difference between the two readings and set your warnings accordingly.
2. Monitors that come from companies that also due tuners typically only allow you to use their programs with their monitors. That makes it limited for you if you wanted someone else's tuner but wanted a different monitor. If you want a monitor despite reason 1 above then you want to get something like the dashhawk or dashdaq or something that does not have built in tunes(like the bully dog PMT or even the outlook as it doesn't have an option for "outlook w/other" for the 6.0ls anymore).
__________________
Fluidampner
Headstuds
FASS 150/180
  #21 (permalink)
Old 05-14-2008, 09:24 AM
I really don't give a rats ass about bolts or studs - I have been running a bully dog on my truck for 3 years at 70% with no issues - I'm tired of hearing what crap the 6.0 is - mine works more than fine and I would take it over a ****ty dodge or chevy any day of the week. The whiners out there need to step off and have a nice tall glass of STFU.
Anyway - the bully dog is ok but my mileage is crap - I want something a little more effectient and maybe some monitoring capabilities.
So.. - What's better the BANKS or the SCT and WHY
Why is everybody slamming the Banks system - they are not my favorite and they are expensive but they seem to have been in the business a very long - I just want a few facts.
  #22 (permalink)
Old 05-14-2008, 09:45 AM
I think I'm going to go with the Spartan but.... Is there anything in the pipe that will be coming out in the next month or two that I should wait for? I saw a few posts on some new tuner that Spartan is comming out with.
Also, I do want to install a pyrometer - anybody have a suggestion for a good one
  #23 (permalink)
Old 05-14-2008, 09:51 PM
brentos's Avatar
brentos is starting off with a positive reputation.
buy and sct not banks i have switched between the two and i will say there is nothing to compare. With banks you dont have hardly anything to change like they say and it is terrible i repeat terrible on the tranny. If you want guages with the sct just get the livewire for eight hundred bucks and i will guarante you will be happy
  #24 (permalink)
Old 05-14-2008, 10:15 PM
I preordered the dashdaq comming out from Spartan for 1200.00 it looks cool DashDAQ Series II - customizable OBD2 gauges, data logging, dianostics, and GPS Navigation
  #25 (permalink)
Old 05-14-2008, 10:24 PM
UGA33's Avatar
Yeah Come On!
UGA33 is gaining momentum as a positive member of FTE.
Good decision. Did he give you any idea when it will be ready?
__________________
2006 F-250 Lariat Crew Cab Shortbed FX4
-Josh-
*6.0L PSD*MBRP Turbo-back*35" BFG Mud Terr. KM2's*Leveling Kit w/ Daystar Coil Spacers & Rancho RS5000's*Spartanized SCT X3*Autometer EGT & Tranny guages*Coolant Filter*CCV Reroute*F-350 blocks*High Idle Mod
  #26 (permalink)
Old 05-14-2008, 11:19 PM
scrufff is starting off with a positive reputation.
How come nobody seems to be running any edge products??They have multiple tuning options,,as well as tranny tuning. Also,,IMO treat things with respect and care,,and they will last forever.
  #27 (permalink)
Old 05-14-2008, 11:23 PM
tex25025's Avatar
Quote:
The percentages of edge products ruining the torqshift tranny on these trucks outweighs those that reported good experiances with them. I can't recall if they used the modules and/or tuners that had the tranny tuning in them(or safety features other then defuel), but I wouldn't take a chance on either one given the numbers.
__________________
Fluidampner
Headstuds
FASS 150/180
  #28 (permalink)
Old 05-15-2008, 11:55 AM
Spartan Diesel tech said the new tuners based off the Dashdaq will be shipping in 2 weeks
  #29 (permalink)
Old 05-15-2008, 05:53 PM
scarm, you my friend are one tough customer. two weeks huh?....I hope so!
__________________
  #30 (permalink)
Old 05-15-2008, 09:42 PM
I'm just going by what the lady that took the order said
I hope cause I have a new camper in the pipe line and it will be ready by the end of May and I can't pull it with my bully dog power pup tunes (or at least that's what they say)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
