6 inch lift biggest tires?
There are a lot of threads on this subject so if you search this forum for "Tire Size", you should find plenty of answers.
Here's a link to an older thread I found that may be of some help.
https://www.ford-trucks.com/forums/4...ombo-size.html
umm the question was answered on post #4 there bud but as was also stated more info is needed to give a proper answer. while you could prob fit 40s if your tryin to climb rocks they might rub where as if its just for looks the 40s will be fine. then yoiu have to take into consideration the undergearing, which in itself is a whole other issue with larger tires. basically i have a truck with x amount of lift tells us nothing.
sorry so used to posting in the 6.0 forum. ya its an 05 f-250, these tires are getting worn and i was just curious at to how big i could go. I did actually look and try to find some answers. everything thats done to it is in the sig. the gearing is stock. Im wondering if it would need to be re-geared maybe 4.10 or could i get by with the stock 3.73 if i went with a 38? I dont tow heavy and yes I use this truck on the sand a lot my 12.5 width got buried kinda quick so this is one of the reasons i wanted a bigger wider tire.
thank you for the info. with wheelspeed as an issue for sand i would seriously consider regearing to at the bare minimum 4.10 with 38s. i think you would be much happier with 4.56 or 4.88s thou. as for how wide. with sand as wide as you can get without rubbing. i dont know the specifics on your truck so i wont say exactly what size you can run but i would think a 38/14.50 would be a nice size to try.
