Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 09:18 AM
Stone Mathews's Avatar
Stone Mathews is starting off with a positive reputation.
Is alignment possible? Truck pulls to right...
Guys,
1999 F250 SD, CC, 5.4L, 4X4, AT, 80,000 miles, stock (no mods)
I have a slight pull to the right. Not terrible, but I notice it on the interstate, it wants to head for the side of the road.....so I keep my hand on the wheel and point her towards the center line.
Noticed last night, while putting new shocks on, that the inside of the driver side front tire is badly worn in comparision to the rest of the tire. The passenger side is also slightly worn more on the inside, but nothing like the driver side.
What can I do?
Thanks fellas.
Stone
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-12-2008, 09:23 AM
redford's Avatar
redford has a good reputation on FTE.redford has a good reputation on FTE.redford has a good reputation on FTE.
It is alignment time, plus you might want to rotate the tires (unless the front tires are so badly worn they are unsafe).
You'll probably also be told that it's time to replace some front end components, like your ball joints.
__________________
ANG Msgt (ret)
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package
5.4L 3.73 LS Tow Command and a
Flamed Dashboard Devil Duck
Presently working as a military contractor in Afghanistan.
  #3 (permalink)
Old 05-12-2008, 12:04 PM
Ace! is starting off with a positive reputation.
Yeah, you definitely want to get an alignment. Alignments are good to get or at least to have checked once or twice a year (unless you hit a curb or something, then you should do it then). I know local places here will do a check for free and only charge you if it's out. They provide a print out of before and after so you can confirm the alignment prior to paying for it.
__________________
2005 F250 V10, CC, SB, 4x4, 4.30 axle ratio
"Deserve's got nothing to do with it"
  #4 (permalink)
Old 05-12-2008, 12:08 PM
03_PSD's Avatar
Still Learning
03_PSD has a good reputation on FTE.03_PSD has a good reputation on FTE.
i agree with Redford, ball joints maybe the culprit.
__________________
Glenn Hook'Em Horns
2003 F250 CCSW Lariat 6 Speed~ProComp Lift~Ranch Hands Front and Back~3 Gauge Pillar~4" Exh. 6" Tip~6637 and Pete's Filter Cover~WW~AIH Delete~ SS HPX~Foil Delete~Alum. Rear Diff Cover~203 Tstat and Billet Housing~Recon Smoke Cab Lights~International Emblems~Fumoto Plug~Reverse Lights~TS Chip~Mildly Upgraded Audio
  #5 (permalink)
Old 05-12-2008, 12:37 PM
Thanks for the replies guys. This being my first 'front solid axle' truck, I wasn't sure what my options are.
Good point about the ball joints. I have not checked them yet.....is it the same way I used to check them on other trucks? Jack up the front, put one hand on top, one hand on bottom of wheel and look for play?
Stone
  #6 (permalink)
Old 05-12-2008, 03:53 PM
redford's Avatar
Exactly, Stone.
__________________
ANG Msgt (ret)
  #7 (permalink)
Old 05-12-2008, 05:52 PM
Brother Les is starting off with a positive reputation.
rotate your tires and check the air pressure before you get an alignment. I ran my tires at 50PSI for two years (had a slight pulle) then I looked on the tires and saw that there should be 80PSI....problem solved.
Brother Les
  #8 (permalink)
Old 05-13-2008, 02:16 PM
Thanks fellas.
I jacked the front end last night. I could not find any play in the ball joints (or any other component for that matter) however, like I said, this is a much larger truck than I am used to, and maybe I'm missing something much more subtle than I'm used to looking for.
However, after reading about alignments, I'm convinced I have a very negative Camber on my front driver side based on the tire wear pattern.
Is Camber adjustable on the front of these trucks?
Stone
  #9 (permalink)
Old 05-13-2008, 02:38 PM
Overkill's Avatar
FTE Sponsor
Overkill is gaining momentum as a positive member of FTE.
If you have eliminated the wear items (i.e. ball joints, unit bearings, spring bushings, etc.) as possibilities, I would also suggest swapping tires from one side to the other to eliminate radial pull as a possible source. When you have the truck aligned be sure to have the thrust angles checked. This indicates how parallel the front and rear axles are to each other. The issue could actually reside in the rear if you have a sagging spring or worn spring eye bushing.
If all else fails adding .25-.5 degree of castor to the right side should solve your issue. Hope this helps
__________________
  #10 (permalink)
Old 05-13-2008, 04:40 PM
Guys, thanks for all the help. I got a couple of recomendations for an alignment shop from some 'old timers' and called ahead. After talking with their alignment guy I feel very comfortable taking it in to have it done.
Prior to that (tonight?) I'm going to check the air in the tires and rotate them just to eliminate that as a problem.
Thanks again fellas!
Stone
  #11 (permalink)
Old 05-18-2008, 09:21 PM
Thanks to everyone for their advice and help, I'm always amazed at what I can learn from this site. (I now know how to inspect and test my ball joints.)
A special thanks to Brother Les, Redford, and Overkill (rep points given). I rotated my tires and inflated my tires to the recomended 50 psi (up from 35 psi) and the problem completely disappeared!!!! I just put 205 interstate miles on my truck and it tracked as straight and true as a plumb bob. It even handles better!!!
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Stone
  #12 (permalink)
Old 05-18-2008, 09:34 PM
DCSpecial's Avatar
FTE Sponsor
DCSpecial has a very good reputation on FTE.DCSpecial has a very good reputation on FTE.DCSpecial has a very good reputation on FTE.
Did you have the alignment done?
As mentioned by Ace, I like to get all my trucks aligned at least once a year.
__________________
  #13 (permalink)
Old 05-18-2008, 10:57 PM
Frankenbiker's Avatar
Frankenbiker is gaining momentum as a positive member of FTE.
Quote:
What can I do?
Thanks fellas.
Stone
This is a classic symptom of incorrect toe adjustment (not camber). The "front" of the tires are "wider" than the "rear" part.
Even if it tracks true, the alignment is still "off". An alignment shop should be able to fix that quickly and easily -- they should not have to go to the effort of a "thrust angle" or "4-wheel" alignment to get it done, although if funds allow, you should go for at least the "thrust angle" alignment.
-blaine
  #14 (permalink)
Old 05-19-2008, 12:52 PM
sealboy84's Avatar
sealboy84 is starting off with a positive reputation.
Hey Stone,
I was having the same problem with my 99. When I got it on the rack, I grabbed the passenger side tire, and could move it back and forth about an eighth of an inch. Time for uppers and lowers...
__________________
'99 F250 PSD LONG BOX X-CAB 4X4
Foil Delete-6637-cold AC Mod-Garmin Navs-Pioneer all the way around (Thanks Steve)
Jay
JOIN NEW MEXICO CHAPTER HERE!
  #15 (permalink)
Old 05-19-2008, 04:14 PM
Nope, I have not had an alignment done yet. I called ahead and talked to the alignment guy and plan to take it in. I could find NO play in my front end components, so I'm hoping that I don't have a ball joint problem. I'm just thrilled that it's not so bad a rotation and inflation couldn't at least mask the problem.
Once I get her aligned I will let everyone know what the shop had to say.
Oh, and they are going to check the thrust angle also. I asked specifically about that.
Stone
Thanks!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
