Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 07:00 AM
mjsizzle is starting off with a positive reputation.
a question about the 5.8 ho engines
ok, i am going to admit to being out of the loop for a while, but i just bought a 85 f-150 supercab someone had started putting a 5.0 from an 82 car into
i am guessing it had a 5.0 before the swap.
it has a c6 tranny and everything seems to be doing fine now that i got it away from that fool, he even had the alt. on the wrong side among many other stupid ignorant mistakes
here is my question, how good are the heads on a 84? 5.8 ho? will they bolt to a 5.0? will the 5.0 intake fit? are the valves bigger? are the ports bigger? will they give me improved performance?will they need to be shaved? for performance i mean
i was just wondering since i found one in a local bone yard that is complete and remembered the 69 4v 351 winsor heads were sooo much better
any opinions?
  #2 (permalink)
Old 05-12-2008, 02:02 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
302 (5.0) and 351w(5.8) heads from 1978-up are the same. Except for the head bolt hole diameters, they are the same heads. If you want any improvement, I think heads off a 5.0 explorer may be some improvement. Aftermarket heads are the best.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 05-12-2008, 05:41 PM
so in other words, the 4v is the "ho"? no other improvements?
  #4 (permalink)
Old 05-12-2008, 05:57 PM
Franklin2's Avatar
No, not much difference except the 4 barrel.
__________________
Dave F
  #5 (permalink)
Old 05-12-2008, 07:47 PM
uncle.stosh's Avatar
uncle.stosh is gaining momentum as a positive member of FTE.
Quote:
Are those the infamous GT40 heads that I keep hearing everyone rave about?
What's so good about them? I know I could google it to find out, but I just thought that maybe you could save me some time.
__________________
Quote:
Originally Posted by tommythomasson View Post
Priming with a drill - what kind of drill did you use? I'm not sure my DeWalt would turn the engine over...
  #6 (permalink)
Old 05-12-2008, 08:13 PM
Franklin2's Avatar
They are known as GT40P heads. I didn't know a lot of the details myself, so here's a link.
StangPro.com - Ford's GT-40P Cylinder Head
__________________
Dave F
  #7 (permalink)
Old 05-12-2008, 08:47 PM
according to my info the 1993,4&5 lightning had the gt40 heads
i'm not absolutely sure about that but i do know the 93 we had with 193k miles when totaled would still run like a raped ape
  #8 (permalink)
Old 05-12-2008, 11:09 PM
tbirdscott is starting off with a positive reputation.
The GT40 heads are fords equivalent of chevy's vortec heads. There's the GT40 and the GT40P heads, only difference I can remember is the spark plug locations, the 'p' heads are in a weird position and cause header clearance issues. They were available on 1993 and up 5.0L HO's.
If your just looking for a better head the E7TE's off the earler 5.0 HO's or 87(?) up trucks are decent stock and with a bit of port work are a good improvement over what you have now and theyre cheap.
If you want to put 302 heads on a 351 you will need to get the head bolt holes drilled out larger, If you want to run 351 heads on a 302 shims are available that fit in the head bolt holes and allow the use of the smaller head bolts.
Scott
Edit: just did a quick google search and found this, some good info to aid in your search.
E7TE vs GT40 vs GT40p heads? - Mustangsandmore Forum Archive
  #9 (permalink)
Old 05-13-2008, 03:09 AM
khadma's Avatar
<I really look like this
khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.
Did these 5.8 H.O.s come from the factory with a dual exit out of a single muffler? I swear I seen some on pre EFI Broncos. (and a test in Fourwheeler mag).
Please let me know if you seen or had one, and were these H.O.s only 49 state options.
__________________
1996 Bronco xlt 5.8,a/t,a/c,31x10.5 BFG's A/T
1999 Ranger supercab xlt 3.0, a/t
1984 Bronco 4.9l, 4spd manual
2002 F150 regular cab shortbox XL 4.2 a/t
1995 Windstar
2007 Explorer XLT 4.0 a/t
1988 Mazda B2200
Member of the Hawai'i Carpenters Union - Local 745
Darren
  #10 (permalink)
Old 05-13-2008, 05:50 PM
Redneck1465 is starting off with a positive reputation.
The GT40P heads have no where near the preformance of the regular GT40. And the H.O.s were 50 state legal.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
