Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-12-2008, 12:24 AM
hollenjoe is starting off with a positive reputation.
Traitor question
Hey I know, i have also an efi 460 in a truck, obiuosly not a 335, im haveing trouble with an electrical fuel punp thats located on my gas tank, i checked for short circuits and i dont let it pass below a 1/4 tank, so any ideas why i have fried 6 of these expensive craps¿ thanks
__________________
"All right baby, see what I´ve got right here in my hands, I´ve got it right in my hands to score you baby, I think im gonna yank on a one town! Look Out!" Uncle Ted
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-12-2008, 12:49 AM
todd31277's Avatar
todd31277 is starting off with a positive reputation.
water in gas? plugged fuel filter. bad reg. have you checked fuel pressure ? where are you buying them from
  #3 (permalink)
Old 05-12-2008, 07:16 PM
JBradley500 is starting off with a positive reputation.
todd, really nice job on your '88...
i mean that, if you really did that transformation, that truck got re-born.
__________________
  #4 (permalink)
Old 05-12-2008, 07:41 PM
danlee's Avatar
danlee has a good reputation on FTE.danlee has a good reputation on FTE.
Quote:
Low Voltage! A DC electric motor will draw more current as the voltage goes down. It's the current that fries the fine wires in the pump. So you need to be sure that it has good connections to 12 volts and ground. Voltage drops across any resistance are the enemy. It can be in the ground circuit as well as the supply circuit. Check your wiring and especially the connections, including that crummy ground connection with all the dirt on it.
Check the pump voltage at the pump feed wires with pins while the pump is running.
__________________
JOIN THE DELAWARE CHAPTER, CLICK HERE
  #5 (permalink)
Old 05-12-2008, 08:07 PM
Thanks , Im gonna get my hands dirty tomorrw on this.. Ill let you know how it goes..
__________________
  #6 (permalink)
Old 05-12-2008, 08:13 PM
danlee's Avatar
Don't blow yourself up. Work in a well ventilated space, like outside, and check for fuel leaks before you make a spark. It's too late to check after.
__________________
  #7 (permalink)
Old 05-13-2008, 05:06 PM
todd31277's Avatar
Smile
really is the same truck. ask my wife she took care of our 3yr twins by herself for 5 months. (:
  #8 (permalink)
Old 05-15-2008, 08:35 AM
palmrose2 is starting off with a positive reputation.
I have to admit that I'm not the biggest Ford man but MANY vehicles have a relay in the pump circuit to give the pump 12 volts while the key is in the "start" position. Once key is released to "run" position, 6 volts is sent to the pump. My understanding is that the pump will last longer running @ 6 volts as opposed to 12. Kind of like a set of points in an old dizzy. If it's always running @ 12 volts maybe that would explain the short life.
Having said this, in my experience, most bad pump relays will run the pump with the starter engaged and start the vehicle until the key is released to the run position and the pump gets NO voltage.
I would at least check into it and see what voltage is supposed to be there at different times.
One more thing. I know that a standard AC motor will draw more amps as voltage drops but was under the impression that DC motors simply slowed down with voltage drop. I'm pretty sure that's what the rheostat that controls the heater motor on our autos does.
__________________
1979 F250 2wd 351 All original 70,000 miles
  #9 (permalink)
Old 05-16-2008, 06:47 PM
Thank you very much, It it was a bad wire and a bad negative.... Any ways just to be sure i rewired the whole thing....
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
