Quote:
Originally Posted by unrulee
No such thing as a factory flex fan.
My choice? My current set up (mech fan with a clutch). Second would be the Taurus fan (cooled great, only reason that I removed it was that the controller that I used died within 2 weeks of installation and I wanted something that was stone reliable).
My factory Flex Fan I took off My 79 truck is part number D7UA-8600-AJA.
It looks just like the on I took off my 77 truck a few years ago.
Don't know what kind of HP you will save changing to something else. In a way it depends on which way you go as how much you will save.
I went with a 16 inch E-Fan off Ebay I got for 29 dollars. I use a adjustable thremostate set to kick on at 220. I have a very clean radiator that works well. My fan almost never kicks on. Therfore it save me more Hp and fuel.
The only real downside to E-Fans is there are NO E-fans made that move as much air as the larger Belt driven fans. One of the OEM 7 blade clutch fans will move more Air than youe engine will ever need for cooling.
An E-Fan still has to be powered. No matter what fan you run it will be run from the "Fan'" belt.
You will see a real difference removing the stock fan especally the higher the rpm you twist the engine.
