Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 09:49 PM
mrgn_mtt is starting off with a positive reputation.
Exclamation AC broken...hopefully not the compressor.
So about a week ago I went to turn on my AC because it was actually kinda warm and it just started blowing out hot air...awesome. So later, in my driveway, I started my truck (1996 F150 4.9 I-6) and turned on the AC. The first thing that I noticed was that the engine didn't strain like usual when the AC compressor was turned on. When I opened the hood, I could hear the AC system going but there was no cold air coming out of the vents. I hope its just out of freon but it sounds to me like the compressor took a crap. Any ideas?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-12-2008, 06:59 AM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
Watch the face of the clutch to see if it's actually spinning with the pulley when the AC is supposed to be on. Bet it isn't.
The clutch cannot engage if the system is low on refrigerant. That's why you inspect the clutch hub first.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 05-12-2008, 12:46 PM
Alright, that would be awesome if I didn't need a new compressor. What do I need to recharge the system?
  #4 (permalink)
Old 05-12-2008, 01:30 PM
Quote:
You need to follow instructions. You have presented no evidence or observation that the system is low on refrigerant.
Do not jump ahead or to an unwarranted conclusion.
__________________
  #5 (permalink)
Old 05-12-2008, 08:30 PM
I wasn't jumping ahead. All I was asking was what I needed if I were to have to recharge the system. And, no the clutch does not spin when I turn the AC on. So according to you, the clutch will not engage if the system is low on freon. So from reading your message and observing that the clutch on the pump wasn't engaging, I can think of 2 conclusions. First, the clutch or the pump may be broken. Second, it might just need freon because, according to you, the clutch on the pump wont engage if there isn't enough freon. That would be what I would try first since getting a new pump would be more expensive. As far as "following instructions," sorry for not reporting back to my every observation before posting.
  #6 (permalink)
Old 05-13-2008, 06:49 AM
Low refrigerant is only one of the possible reasons the clutch is not engaging. A pressure check with a gauge will answer the question of whether or not the system has leaked down.
If it is low, the system requires the leak to be repaired and evacuated properly before recharging.
Might be a blown fuse, a bad pressure switch, bad relay (is used), worn clutch, etc...
__________________
  #7 (permalink)
Old 05-13-2008, 10:59 AM
hhott71 is starting off with a positive reputation.
Its spring.
Many shops are offering AC Check specials.
Take advantage of having a professional diagnois the problem.
Its cheaper and safer than throwing parts at it.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
