Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 08:27 PM
Chevyboy_0 is starting off with a positive reputation.
Veggie Oil?
I'm sure this has been brought up many times before but what would it take to convert a 1987 F-250 6.9L/4Spd to run on Veggie oil?
__________________
1987 F-250 6.9L/4Spd *Blown Head Gasket*
1970 Chevelle SS 350/TH350 *ALMYDOE*
  #2 (permalink)
Old 05-11-2008, 08:35 PM
willbd is starting off with a positive reputation.
"Just do it"
I am starting my 3rd year on WVO with my 95 PSD.
The best way is to run a 2 tank system. 1 tank is for your veggie and the other is for Biodesel or Diesel.
In the veggie tank install a heat exchange and make a heated fuel line and filter.
You can buy a kit to convert or you could build it your self.
Some people do the mixeed veggie and Diesel.
Good luck and let us know how it's working for you.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
  #3 (permalink)
Old 05-12-2008, 10:58 AM
what do you mean by heat exchange?
__________________
  #4 (permalink)
Old 05-12-2008, 11:32 AM
TXHillCountry's Avatar
Aggie Network
TXHillCountry is starting off with a positive reputation.
Go check out one of the "conversion kits" to get a good idea of what a "straight VO" system looks like. Like Greasecar Vegetable Fuel Systems
Basically how they work is this:
You have two tanks, one for the straight VO, and one for diesel. You start the engine on diesel. Once the engine is running, some method for heat is sent to the tank containing the VO to start heating it up. Most common is to use the radiator water lines run through a "coil" or some type of heat exchanger in the VO tank. Once the VO is heated enough (thin enough) to use, you switch over to the VO tank and run on that until it's time to shut down. Then you switch back over to the diesel tank to flush the fuel lines and injectors (you don't want VO sitting in those lines or injectors or it will gel). Then you shut down.
A commercially available conversion kit will usually have all the parts you need for the conversion, AND some will offer automation of the switching. The automated systems will monitor the temps and do the switching from one tank to another for you.
While I like the technical feasibility of it, here's my problem with a conversion kit. If you are technically inclined enough to build your own, then great. However, if you buy an off-the-shelf kit, they can be very pricy, almost the same price as an entry level bio-diesel processing system. So why not put the money in a bio-diesel processor and be able to use that fuel in any diesel vehicle, not just one vehicle that has a conversion kit?
Pros and cons both ways.
TX
__________________
  #5 (permalink)
Old 05-12-2008, 11:36 AM
Quote:
I have a heat exchanger in the front tank to warm the veggie oil. If it’s less than 70 F out veggie oil does not flow very well.
I have 4 heat systems to heat my oil. First is in the fuel tank. It’s a transmission oil cooler that has engine coolant flowing through the cooler and it sits on the bottom of the veggie fuel tank. I have 18 feet of hose on hose fuel line. Coolant flows through one hose and veggie oil through the other. 12 volt 200 watt heater that raps around my veggie oil fuel filter. Arctic Fox fuel heater that uses coolant to heat the fuel.
Arctic Fox Inc. Products for cold weather, diesel fuel heating, tube bending and outdoor products
__________________
  #6 (permalink)
Old 05-14-2008, 05:28 PM
akghound is starting off with a positive reputation.
Look Here
Checkout this site Frybrid Vegetable Oil Fuel Systems There is also a forum there with lots of info.
  #7 (permalink)
Old 05-15-2008, 12:18 PM
Sandblaster01 is starting off with a positive reputation.
I have been running an F250 with a Goldenfuelsystems.com system since March 2008. I ran it during cold days (~20 degrees) without problems. Their system uses tubes from the coolant system to keep the oil hot. I didn't see any lag in power during the cold months. I am now getting into the warm months and am enjoying the longer run time because the oil is already heated in the black tank in the bed of the truck.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
