Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 08:14 PM
99f350sd is starting off with a positive reputation.
Rotor Replacement Question??
Has anyone had good luck with rotors. Finding some that won't warp..My factory fronts need replacing. I had them cut once and now they are warped again...
Thanks
Dick
__________________
99 F350 5.4 Lockers,Warn winch,Hubs..Diablo Predator
MDII Plow, 200 amp alt timbrens,Revo's
85f150, Two 96 aero*awd 4.0 ext. 05 mountaineer V8 Awd
Lever's are cool enough for me too...LOL
  #2 (permalink)
Old 05-12-2008, 01:03 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Use ceramic brake pads, make sure all the brakes are properly adjusted, and use a lathe to cut a cooling groove. The warped rotor indicate the front brakes are working too hard. If you use the parking brake periodically, it helps ensure that the correct brake ratio is maintained.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #3 (permalink)
Old 05-12-2008, 11:27 AM
marragtop is starting off with a positive reputation.
Also, make sure the wheels are torgued properly. Don't let the tire jockeys over torgue them with air tools. Over torguing will result in warping.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
  #4 (permalink)
Old 05-12-2008, 02:37 PM
spikedog's Avatar
spikedog is starting off with a positive reputation.
Quote:
That's interesting. Is that true for all FORDS, or just explorers? How does that work? I thought you just had to put the brakes on solidly while backing up once in a while, and they should self-adjust.
__________________
If there are no dogs in Heaven, then when I die I want to go where they went. -Will Rogers
  #5 (permalink)
Old 05-12-2008, 04:36 PM
Sponsor
This should be true of all Fords. The auto adjusting tensioner is activated and operated by the parking brake mechanism. Putting on the brakes while backing up is not any different than doing so in forward.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
  #6 (permalink)
Old 05-12-2008, 05:20 PM
87 XLT is starting off with a positive reputation.
On my 87 Ranger the rears do self adjust when backing up & hitting the brakes.
But, i think on most newer Fords the self adjusters are only activated with the parking brake.
I read that a lot of vehicles in Florida were chewing up front brakes because it's so flat there & theres no need to use the parking brake.
The rears get loose & the fronts do all the work.
My wife never uses her parking brake, so once a week I pump it 10 times to keep the rears adjusted.
  #7 (permalink)
Old 05-13-2008, 10:23 PM
460's Avatar
460 460 is offline
Magician
460 is starting off with a positive reputation.
Is this true of all Fords, or just the ones with disc brakes in the rear?
  #8 (permalink)
Old 05-13-2008, 10:29 PM
460's Avatar
460 460 is offline
Magician
Quote:
Thanks
Dick
The rotors will warp quicker after turning them because they can't dissipate the heat as well as they did when they were thicker. I've suspected some shops of spinning them down to nothing so they will warp quick and you'll be back to buy new ones...
Quote:
Excellent advice, and so little known and so often overlooked. Torque wrenchs are for torquing lug nuts; not impact wrenches. Using an impact to torque the lug nuts is a good way to get a bent wheel also.
  #9 (permalink)
Old 07-02-2008, 01:10 AM
Rainbow ST is starting off with a positive reputation.
I know I am late coming in.. but one more thing about the impact wrench. If you have aftermarket rims with those "keyed" lug nuts, don't let them use the impact gun on them. I had a $2 lug nut from a chrome rim end up costing me $900 to fix when they broke the lug nut with the gun, and we ended up having to cut the rim to get it off the truck and then still had to cut the stud off the rear hub.
I also found that most of my threads were eaten up because the guy I took it to insisted on using the gun. So I ended up having the thing restuded and buying new front rotors.
__________________
  #10 (permalink)
Old 07-03-2008, 12:15 AM
460's Avatar
460 460 is offline
Magician
Quote:
Did they even attempt to remove the broken locking lug nut? Usually they can be removed by hammering a socket over them and then zipping them off with an impact. It isn't good for the socket, but I've gotten off every one I've tried like that.
  #11 (permalink)
Old 07-04-2008, 10:25 AM
jasongt06 is starting off with a positive reputation.
Driving habits also can warp rotors as people ride the brakes which causes them to build up excess heat which will warp them.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
