Join Our Site - Its free, quick and easy!
Click Here to join.
This Section Sponsored By
05-11-2008, 07:08 PM
1989 f450 engine question
hello,
was the 351C available in the 1989 f450?
thanks
gregg
Sponsored Links
To remove this ad, register today!
05-11-2008, 07:43 PM
No. My guess is that it's a 460.
__________________
JOIN THE DELAWARE CHAPTER, CLICK HERE
05-11-2008, 07:49 PM
any way to tell from the vin?
2FDLF47G0KCB21589
05-11-2008, 10:13 PM
Your VIN number: 2FDLF47G0KCB21589
World Manufacturer Identifier - 1st, 2nd, 3rd Positions:
Manufacturer: Ford Motor Company of Canada, Ltd., Canada
Make: Ford
Vehicle Type: Incomplete Vehicle
Brake Type and GVWR Class - 4th Position:
Brake System: • Hydraulic brake system, Class 4, GVWR 14,001-16,000 pounds, None
Line Series, Chassis Type, Body Type - 5th, 6th, 7th Positions:
Line Series: F-Series Super Duty
Chassis Type: 4x2
Body Type: Chassis Cab - Regular Cab
Engine Type - 8th Position:
Engine: 5.8L (351cid)
Cylinders: V-8
Fuel Type: Gasoline
Horse Power: TBD
Model Year - 10th Position:
Model Year: 1989
Assembly Plant - 11th Position:
Assembly Plant: Ontario Truck: Oakville, Ontario
Production Sequence Number - 12th - 17th:
Sequence Number: B21589
It would be a 351 windsor there is a VIN decoder located under articles/specs at the top of this page.
-Johnboy
__________________
-1979 F-250 4X4 400 4spd
-1989 Bronco 300six swapped in ZF 5spd
-1967 Mercury Comet Sports Coupe
05-11-2008, 10:39 PM
Quote:
Originally Posted by
johnboy427
Make: Ford
Chassis Type: 4x2
Cylinders: V-8
Fuel Type: Gasoline
Horse Power: TBD
Model Year: 1989
-Johnboy
https://www.fleet.ford.com/maintenan...vinResults.asp
ford fleet site decodes the same vin w/ a 7.5L motor
VIN: 2FDLF47G0KCB21589
World Manufacturer Identifier - 1st, 2nd, 3rd Positions VIN Code: 2FD Assembly Country: Canada Make: Ford Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position VIN Code: L Brake System: HYDRAULIC GVWR Class: Class 4 GVWR Range: 14,001 - 16,000 Pounds Line,Series Body Type - 5th, 6th, 7th Positions VIN Code: F47 Vehicle Line: F-Super Duty Body Type: CONVENTIONAL Vehicle Type: Truck/SUV Engine Type - 8th Position VIN Code: G Engine: 7.5 L Cylinders: 8 Fuel: Gasoline Model Year - 10th Position VIN Code: K Model Year: 1989 Assembly Plant - 11th Position VIN Code: C Assembly Plant: ONTARIO TRUCK: OAKVILLE, ONTARIO, CANADA Production Sequence Number - 12th - 17th VIN Code: B21589 Prod Sequence Number B21589
05-12-2008, 01:04 AM
Guess the one here is wrong never seen that before sorry, to tell a 460 from a 351 the 460s thermostat housing will be on top the intake manifold and angle forward the 351s will come off the front and angle up. Well it isn't a 351C it was discontinued in 1974 and never offered in a truck.
-Johnboy
__________________
05-12-2008, 09:02 AM
Plus a 460 will look uber big when compared to a 351W.
05-12-2008, 05:12 PM
IIRC the 351W was the base engine only for a few years. 460 was the base later. And the 7.3 diesel being the only engine option then.
__________________
Real men don't wear Bowties
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
